I searched a few posts, and found some info. It seems these are inexpensive roof rack baskets that look good. Not so much looking for utility, just looks!
I have the factory rack, with the crossbars. Also has a sunroof.
I have a 10-year old Rola that has held up great. I did make a few mods to improve the overall set-up, but I don't think you'd need to go that far.
The only caveat is the OEM bars are a bit on the flexy side and you may see that transfer to the rack a bit when things get bumpy.
__________________ Build Etc...
If it ain't broke, fix it 'til it is.
I bought the Rola on Amazon for $165. It seems using the factory rails will not look great, so I will be doing what this guy did. Seems easy and rather inexpensive.
I ended up getting the Rola, and also doing the brackets that Pho Runner did. Take a look at the link below (Some Pics)
it was really easy, and cheap! and it's solid. I tried putting on the OEM rails, abut was not stable at all. this gives it a good look, is solid, and also not mounted super high.
2002 4Runner 2WD
292K miles and counting! Some Pics
