Originally Posted by 19963.4lsr5
I’m on the shelf with regard’s to needing the entire repair sleeve if all I need to do is replace the inner steel from the lower control arm mount to the cross member for the shock mounts.
The shock mount needs some TLC while I’m in the area.
Understandable. I done 2 with just plating.
You can cut out the rot then slide a plate inside to attach it back together then weld a plate over that to Seal it all back together.
This way if using 1/8 plate your end up with 1/4 of steel in like a plywood fashion.
I really wish you lived closer as it's alot easier to do that plating on a car lift...
The shock plate area is one of hardest areas to do. I mostly either plasma cut the front of the frame out and plate the inside then weld it back together.
Or I plate under the coil plate.
Its alot stronger if you just go in front the c side and plate it up good inside. Then a thin plate on the thin side to tie it back together. I have had those coil plate come loose before. You do not want that happening...:/
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
