Old 01-31-2023, 02:41 PM #46
It’s in place and within 1/32-1/16” of where it should be front to back.
Time to burn it in.
Old 01-31-2023, 03:13 PM #47
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Those pre forned section plates look like they fit perfectly. Good job.
Old 02-08-2023, 03:59 PM #48
I’m finally off for two days. Sticking it back together.
Old 02-08-2023, 04:52 PM #49
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Decent weld.. That will work.
Old 02-17-2023, 06:17 PM #50
Trying to finish it up. Since the sleeve wouldn’t bottom out on the frame this is all I could think of doing.
Old 02-17-2023, 06:26 PM #51
Old 02-17-2023, 06:34 PM #52
Sadly my Roto-Zip gave up the ghost this afternoon grinding the Lower Control arm mount back to expose the repair sleeve to weld it to the frame.
I figured it be dead soon. It’s on its third set of bearings. I’ve beat the crap out of it since I bought it in the early 2000’s. Lately it’s been my Die-Grinder.
Old 02-17-2023, 08:23 PM #53
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I was looking for a small die grinder. I have 2 dremels but that roto zip may come in handy...:-)
Good to see you have it within a 1/16 to 1/32. Great job...:-)
Old 02-19-2023, 09:04 PM #54
It’s welded and painted and on the ground. I need new bolts for the running board so it’s the only thing not finished. I’ll drive it tomorrow to work and see where my steering wheel ends up.
Old 02-19-2023, 09:21 PM #55
I ended up buying a Dremel. The new current Roto-Zip isn’t anywhere close to my old one. Plus the 1 1/2” mini cutoff wheel is what I needed.
Old 02-20-2023, 11:18 AM #56
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Great job on all of this! On top of that, I hope you enjoy the new SPC lower links. ;)
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 02-20-2023, 01:11 PM #57
My steering is now just right of center.
Old 02-21-2023, 02:45 AM #58
ruthimperial ruthimperial is offline
ruthimperial is on a distinguished road
최고의 온라인 플레이 바카라 무료로 게임을 플레이하고 지금까지 경험하지 못한 넘치는 가격을 발견하십시오. 그래서 당신은 무엇을 기다리고 있습니까? 지금 플레이하세요!
ruthimperial is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 04:17 AM #59
whyzee125 whyzee125 is offline
whyzee125 is on a distinguished road
I got a crooked steering wheel after just replacing my rear control arm bushings with the Energy suspension poly bushings. I'd say it was off a good 10 degrees, and both the stock bushings and those basically have to 'center' so I'd say if I got that much off with the bushing replacement, you are VERY close to the stock location. Nice job!
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 05:13 AM #60
Repairing the Passenger Side Rear Lower Control Arm Rusty Mount.
The bushings in my old arms were not horrible looking.
When I first went to put the arms in I had to use a come-a-long to get the bolt holes lined up. Laying the old ones on top of the new ones the newer ones looked shorter by about 1/8”.
Edit: other than the steering wheel not being strait ahead the steering is tight and the rig tracks strait over bumps and tire grooves.
drivers , it’s , mount , repairing , side
Driver side front and rear lower than passenger side! gyro09 3rd gen T4Rs 3 07-14-2016 04:21 PM
Frame failure at rear lower control link mount Steve240 3rd gen T4Rs 1 05-20-2015 05:11 PM
WTB 4th Gen. Passenger Side Lower Control Arm grantprior13 For Sale: Suspension/Wheels/Tires 3 03-22-2015 01:53 PM
WTB: 4th gen rear lower control arm (rt side) sasquatch Want to Buy/Trade 3 03-24-2010 12:49 PM
Driver side one inch lower than passenger. Why? cliffw2000 3rd gen T4Rs 10 12-24-2009 03:52 PM
