Old 01-25-2023, 07:38 PM #1
19963.4lsr5 19963.4lsr5 is online now
Repairing the Passenger Side Rear Lower Control Arm Rusty Mount.
The drivers side literally broke off the frame a few years ago. It’s fitting that now it’s the passengers side time.
This will be more involved that the drivers side repair.
I’ve been paranoid since I fixed the drivers side mount. Experiencing a weave driving strait for no reason.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 01-25-2023, 09:56 PM #2
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Ughhhh…..freaking rust never sleeps.
Are you equipped to do it yourself or bringing it to a shop experienced with welding/fabrication.
Good luck with that repair and keep us posted along the way.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 10:34 PM #3
MCgrease08's Avatar
MCgrease08 MCgrease08 is offline
MCgrease08 is on a distinguished road
MCgrease08's Avatar
I just had mine done too.
I had a shop weld in a Safe-T-Cap. They were one of two authorized installers in the state of Indiana. I envy guys skilled and equipped enough to do the repair themselves.
Doesn't the passenger side usually go first because it's next to the hot exhaust pipe?
MCgrease08 is offline   Reply With QuoteReply With Quote
Old 01-25-2023, 11:35 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have faith that the OP can get that fixed... :-) He patch that right up. The Safe T caps are one option. Another option is to build your own plates and cut out the rot replacing the rusty steel. :-)
Those Lower rear control arm bracket areas of the frame are always a bad area for the rot.
Old 01-25-2023, 11:38 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Not always but you are correct on the heat and cooling from the exhaust is extremely hard on the steel.
Old 01-26-2023, 02:44 AM #6
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
This place sells them as a set or individually. Just cut out the old and weld in the new.
Mid-Rear Frame Section (ART-218-S) Set - autorust.com
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 10:45 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
We used Safe T caps to rebuild a 03 Tacoma frame. They are a good product.
Old 01-26-2023, 10:51 AM #8
Yep, in a few days I’ll have two of them in my rig.
Old 01-26-2023, 10:54 AM #9
When I’d actually ran across a 4Runner in the junk yard it was always the drivers side that rusted off. But I only ever ran across thee of them and two were there for drivers side rotted off.
Old 01-26-2023, 10:56 AM #10
Today I need to remove the running board and the exhaust heat shields. Depending on how long that takes will determine if I start removing metal.
Old 01-26-2023, 11:48 AM #11
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Good luck! Hope it all goes smoothly.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 11:57 AM #12
Another picture.
Heading out to fire up the heater and spray all the bolts.
Old 01-26-2023, 01:11 PM #13
nissanh nissanh is offline
Hope the process will go smooth. The rust is what keep me away from PA! Lived in Central PA for 4 years.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 01-26-2023, 02:25 PM #14
Well, the two heat shields are removed with no broken studs.
Time for the running board…..
Old 01-26-2023, 04:45 PM #15
Here are better pictures with the running boards and heat shields out of the way.
Inside
Outside
drivers , it’s , mount , repairing , side
Driver side front and rear lower than passenger side! gyro09 3rd gen T4Rs 3 07-14-2016 04:21 PM
Frame failure at rear lower control link mount Steve240 3rd gen T4Rs 1 05-20-2015 05:11 PM
WTB 4th Gen. Passenger Side Lower Control Arm grantprior13 For Sale: Suspension/Wheels/Tires 3 03-22-2015 01:53 PM
WTB: 4th gen rear lower control arm (rt side) sasquatch Want to Buy/Trade 3 03-24-2010 12:49 PM
Driver side one inch lower than passenger. Why? cliffw2000 3rd gen T4Rs 10 12-24-2009 03:52 PM
