Old 01-27-2023, 10:48 AM #16
Dexron 3 vs Dexron 6 in Transmission
Originally Posted by JoeT4R View Post
I wouldn't be opposed to that, I used to run PUP in my engine for a few years and had great results with it. I'm not sure I've seen that stuff locally though.I feel like this is the most readily available and might be what I end up having to use if I don't want to be bothered with paying for shipping for AMSOIL.
Sent from my SM-S908U using Tapatalk
It’s not easy to find. My friends trans shop is also a Pennzoil Quick Lube and they stock it.
When I put a tighter torque converter in my Cummins in 1996 the trans shop used multi vehicle. It had 180,000 miles on it and still chirped the tires WOT on 1-2 upshift.
Also used it in some GM transmissions.
Old 01-27-2023, 11:51 AM #17
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Plus it's a conventional fluid and not synthetic. That would be the thing for me. I prefer to have a synthetic fluid in there.
Valid point but it was designed to have that fluid in it. Its a slightly thicker and probably even shifts smoother as well. :-)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 01-27-2023, 02:10 PM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
But what if you mix Dex VI and III in the trans? Is that okay to do?
Sent from my SM-T220 using Tapatalk
Mixing them won’t cause any issues.
Old 01-27-2023, 03:30 PM #19
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
All things considered, my trans has been good to me and the fluid has never become discolored and I've never experienced any issues with it (knock on wood)
So I must be doing something right with regular drain and fills. The shifting feels smooth, but I've also only driven this thing for the past 10 years so I don't really have much to compare it to, either. I'll keep doing what I'm doing as long as I get good results.
Old 01-27-2023, 03:44 PM #20
We have a drain plug which makes it so much easier.
Old 01-27-2023, 03:47 PM #21
JoeT4R's Avatar
JoeT4R's Avatar
That's the truth. I don't think the 4th gens do. No idea about 5th gens. I've been trying to do annual drain and fills anyhow.
Old 01-27-2023, 10:21 PM #22
JoeT4R's Avatar
JoeT4R's Avatar
$82.36 for 4 quarts of AMSOIL multivehicle ATF... I think I'm going to have to pass on that. And that's pre-shipping, too. Walmart, here I come.
Old 01-27-2023, 10:48 PM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You have to do what you have to do..
Old 01-29-2023, 10:59 AM #24
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Nothing wrong with that at all..;) I don't run it because 3 gallons if it is quite expensive anymore.
It was $110 w/tax for 13 quarts at local dealer, not too bad. In one year (5K) I'll do a full drain (x4) using valvoline blue and go annual from there.
Luck to us all !!
Old 01-29-2023, 02:19 PM #25
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
Yes my 5th does, drain and fill every 15k.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 02:34 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Most transmissions pans have drain plugs. The ones without dipsticks mostly have a fill plug like the diffs do..
Old 01-30-2023, 04:31 PM #27
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
At 60K I did a fluid swap and put Mobil 1 Synthetic ATF in the trans. I'm at almost 155K now and planning to do a fluid swap again.
I was going to use the Valvoline Maxlife but the Mobil 1 is on clearance at Autozone. Depends on region I think but it's anywhere from $2 - $6 a quart at present. I bought 13 quarts, all my local Autozone had in stock and will be using that in the trans again.
Speedy is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 05:55 PM #28
I got ATF+4 from them on close out for 99 cents a quart. I still got 3 gallons left….sold my truck that used it.
Old 02-09-2023, 05:35 PM #29
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Originally Posted by RootedWanderer View Post
Best word of advise.... Use what the manual says you should use. They manufactured your vehicle to a certain set of standards. Better standards can come out, but guess what... your vehicle wasn't built to those "better standards"
My thoughts precisely.
Using Dex/Merc conventional fluid here. No issues, and not interested in creating issues by changing fluids to what's trending.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 09:37 PM #30
JoeT4R's Avatar
JoeT4R's Avatar
Are you using a machine for a full fluid exchange or just doing multiple drain and fills?
dex , dexron , gonna , good , transmissions
Dexron II in my "02 gebomartin 3rd gen T4Rs 13 05-06-2019 02:32 PM
Dexron VI for your 3rd 4runner 02runner4 3rd gen T4Rs 3 01-29-2014 07:01 AM
Duh Moment. Dexron IV NOT ATF+4 DC runner 4th Gen T4Rs 4 03-22-2012 08:53 AM
Adding Dexron VI into Dexron III? t65k3 4th Gen T4Rs 0 08-22-2010 04:37 PM
Atf Dexron Ii Or Iii? limited4wdman Maintenance/Detailing 3 12-29-2005 01:11 PM
