Old 02-10-2023, 12:46 PM #31
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Originally Posted by JoeT4R View Post
Are you using a machine for a full fluid exchange or just doing multiple drain and fills?
Sent from my SM-S908U using Tapatalk
The one I did at 60K I used some kind of transfer machine I had access to at the time. You fill up one side with new fluid, hook it up, and it swaps the fluid.
I'm about to do it again 100K miles later and I'm going to drain the trans at the pan. Refill with however much comes out. Then disconnect the trans line at the radiator and put it in a big bucket. Fire up the truck and let it drain while I add fluid at the dip stick port.
I got this bucket since it's graduated and was on sale for $12 Amazon.com: Rubbermaid Commercial Space Saving Food Storage Container, 8 Quart, Clear (FG630800CLR) : Home & Kitchen
I was gonna go with Valvoline Max ATF, but when I was at the store getting supplies I saw they had Mobil 1 Synthetic ATF on clearance for like $6 a quart so I bought all they had (13 qts) and will just use that. I used Mobil 1 Synthetic ATF at 60K and it's been great for the past 100K.
Speedy is offline   Reply With QuoteReply With Quote
Old 02-10-2023, 03:33 PM #32
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I gotcha. I picked up some Valvoline MaxLife ATF this morning from Walmart (a 5 quart jug/1gal) for $27.48 out the door. Not horrible but it'll do the job and it'll do it well so I'm not going to lose sleep over it. I can't afford to run AMSOIL right now so this will have to be the next best thing. I didn't see any Mobil1 ATF there, at least that I recall.
Old 02-10-2023, 04:44 PM #33
Speedy's Avatar
Speedy's Avatar
The Mobil 1 Synthetic ATF I found on clearance was at Autozone. Depends on region I think but the online price was anywhere from $2 - $7 until you put in your zip. Wish I'd gotten the $2 ones lol but $6 wasn't bad considering they were like $14 normal price for the quarts.
Old 02-10-2023, 07:20 PM #34
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have graduated buckets when I change mine.
I use clear hoses, too. I just been experimenting with thr transfer pumps. The Amazon pump on the cheaper side are junk.
I have a disel transfer pump that works well just way to big of the inlets 1 inch.
I am hoping fuel pumps will work as that be a simple setup
dex , dexron , gonna , good , transmissions
Dexron II in my "02 gebomartin 3rd gen T4Rs 13 05-06-2019 02:32 PM
Dexron VI for your 3rd 4runner 02runner4 3rd gen T4Rs 3 01-29-2014 07:01 AM
Duh Moment. Dexron IV NOT ATF+4 DC runner 4th Gen T4Rs 4 03-22-2012 08:53 AM
Adding Dexron VI into Dexron III? t65k3 4th Gen T4Rs 0 08-22-2010 04:37 PM
Atf Dexron Ii Or Iii? limited4wdman Maintenance/Detailing 3 12-29-2005 01:11 PM
