Old 06-01-2023, 08:05 PM #241
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Originally Posted by Speedy View Post
I don't want it shiny, just satin like it was originally and so far so good. Not too hard to clean it up.
It was probably a bead blast finish originally. It'll be tough to get the right finish with sand paper. It'll be very interesting to see your results.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-01-2023, 08:17 PM #242
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
I'm finding sanding in one direction makes a big difference
Speedy is offline   Reply With QuoteReply With Quote
Old 06-01-2023, 11:50 PM #243
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If you don't sand in circles, you can get the surface uneven. Maybe not a big deal in your particular project. I just learned what I learned from a professional body folks.
Old 06-02-2023, 01:12 PM #244
Speedy's Avatar
Speedy's Avatar
Body work over filler for sure. This is just removing oxidation from the sport skid. Going in circles changed the finish from a smooth satin to just swirls and scratches. I found going back and forth horizontally got rid of the oxidation, maintained a satin finish, and then I just put a bit of metal polish on a pad attached to a drill and finished it up. Came out looking like new.
Old 06-02-2023, 06:48 PM #245
Speedy's Avatar
Speedy's Avatar
I looked like a chimney sweep when I got done with this one. Everything under the truck from skids to spare and the frame and chassis as well as all bumper bracketry have been degreased, cleaned up, and a fresh coat of satin black paint applied. It all looks brand new. Replaced any bolts that looked bad as well with brand new factory Toyota bolts and coated the threads with anti seize before I put them in. Put some Rust Reformer on the back of the chrome bumpers for the surface rust and hit that with some satin black as well.
Video in third post. To do list is getting pretty short now.
Next up will be a refresh of the interior.
Before
After
Old 06-02-2023, 07:00 PM #246
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Wasn't barely rusty to begin with. I agree looks better...
Old 06-02-2023, 08:09 PM #247
Speedy's Avatar
Speedy's Avatar
I feel better knowing it's all sealed up and protected.
I can't think of much else I need to do maintenance wise. The steering rack is good, bushings seem good, axles and boots good.
I will swap out the fuel filter again. It's due but I swapped the one on my riding mower after 15 years and cut it open and it was like brand new inside so probably not a huge deal.
Now I can move on to some more fun stuff.
Katzkins ordered. Found a guy on the Tundra forum that did forum discounts
Old 06-13-2023, 07:05 PM #248
Speedy's Avatar
Speedy's Avatar
Small update. Custom interior is still on order and hasn't arrived yet. Maybe next week.
In the mean time I disassembled the console to install the new leather cover from JF Customs on Ebay. Again I HIGHLY recommend them, super good to work with and the cover is actual leather and high quality at that.
Once I got the console removed/disassembled (easy) I realized it takes a special staple with a 3mm leg. This is a very short staple to avoid going through the thin plastic when stapling the leather to the console lid and isn't a standard staple. My console also needed a bit of a beef up in padding and I planned to use some 1/4" thick neoprene for that and some spray adhesive to put it all together. Finding a pneumatic staple gun for the special staples turned into a bit of a project and cost for something I'd likely use one time. I considered adding some leather or vinyl strips to the back side of the console lid to allow for use if the 1/4" staples but meh.
I went by the upholstery shop I'm going to have install the custom leather when it arrives to ask what they'd charge me to put the console cover on. Free was the answer since it was such a simple job and they'd add the necessary additional foam to boot. Got it back and it looks great. Can't beat free. I'll buy the guy lunch when he does the seats as a thanks.
Next up will be the new interior and I can't wait to see how it looks.
I still have extra JF Custom console covers. If you can use one lemme know, cover shipping and it's yours.
I got the JF Customs console cover black with tan stitching and I think it looks pretty good with the oak interior.
Old 06-14-2023, 07:43 PM #249
Speedy's Avatar
Speedy's Avatar
This is just a test to see if this image shows up.
Old 06-19-2023, 05:27 PM #250
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
The image isn't showing up for me, but I'm also viewing this on my tablet. Just wanted to let you know Speedy!
Sent from my SM-T220 using Tapatalk
Old 06-19-2023, 05:46 PM #251
Speedy's Avatar
Speedy's Avatar
It was an image from faceplace. Seems it showed up for a while and has now disappeared.
My webhosting company tripled the yearly rate and I'm not renewing. Pics will soon go poof unfortunately. I may get a new provider, still thinking if I really need it.
Old 06-19-2023, 06:45 PM #252
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can pay for tapatalk pro and they store the photos.
Old 06-20-2023, 09:16 AM #253
JoeT4R's Avatar
JoeT4R's Avatar
Tapatalk, Flickr, etc. Those are two sources I use and have good results with.
Sent from my SM-S908U using Tapatalk
Old 06-20-2023, 09:48 AM #254
Speedy's Avatar
Speedy's Avatar
Looks like the image from faceplace is back, well shows up on my phone anyway.
Old 06-20-2023, 11:21 AM #255
Speedy's Avatar
Speedy's Avatar
Originally Posted by RodrickHeffley View Post
cover installed
I've started installing my East Detailing cover. It's quite a bit different from yours so probably explains the price difference. Mine looks to fit a bit better especially around the spokes (goes all the way down the spoke like factory) and has a very nice contrast stitch.
I expected the install to be harder to be honest. I'm kind of enjoying it. Relaxing.
fluid , miles , rear , recondition , replaced
My better late than never build thread gm350reratliff 4th Gen T4Rs 118 09-06-2022 12:19 AM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
