Old 02-28-2023, 09:38 PM #31
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Originally Posted by gamefreakgc View Post
Almost assured you will need one. My tires were so out of whack they squealed as I drove down the driveway. Was an interesting drive to the dealership to get them aligned!
I agree will find out shortly.
Speedy is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 10:17 AM #32
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am kinda surprised the rigs would need to be realigned after changing ball joints but come to think of it. I almost always have mine aligned after that project or new tires installed. As the pot holes around here make daily driving, sometimes an off-road experience. :/
Old 03-01-2023, 11:59 AM #33
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I had to unbolt my LBJ's from the knuckle to change axle shafts and that alone caused my steering wheel to be off center now. I'm sure my toe is out too, but I really don't want to have to break out the fire wrench again.
Old 03-01-2023, 02:58 PM #34
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I keep it in mind, I actually end up doing it like 95% of the time. and its great to know that its you mess with the ball joints and tie rods its a great idea to get an alignment done.
Even though, you don't change the parts :-) Naturally, changing the tie rod ends you need alignment. I just did think taking off loose a lower ball joint and bolts that were torqued
to spec. to change a CV joint. Then new lower ball joint bolts I would need to have the alignment checked.
Old 03-01-2023, 08:29 PM #35
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Heh, Jon you should come visit northern Virginia then, lol! Pot hole city over here buddy.
Sent from my SM-T220 using Tapatalk
Old 03-01-2023, 08:35 PM #36
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Same environment. Doesn't surprise me..
Old 03-02-2023, 04:35 PM #37
Speedy's Avatar
Speedy's Avatar
I guess Toyota valve cover gaskets and spark plug tube seals are still the go to? My originals lasted about 18 years and 130K miles before they started to have any sort of leak so that's pretty good.
I need to get that ordered.
Old 03-02-2023, 04:38 PM #38
JoeT4R's Avatar
JoeT4R's Avatar
I'd say so. I wouldn't feel comfortable using anything other than OEM components for that job in particular. And any price variation for something aftermarket I don't think would give me peace of mind.
Sent from my SM-S908U using Tapatalk
Old 03-02-2023, 04:43 PM #39
Speedy's Avatar
Speedy's Avatar
Book time on the valve cover gaskets is 3 hours. Why do people say it takes them 8 or 12?
I typically take my time and goof off when I'm working so I'm sure it'll take me longer than 3 hours, plus I'm super anal about cleaning stuff up so that'll probably slow me down too. I plan to paint the valve covers with some silver (or red?) engine enamel to clean them up.
Old 03-02-2023, 04:43 PM #40
JoeT4R's Avatar
JoeT4R's Avatar
Also, something I want to add that I forgot to mention. Those half moons are something to do as well during the VCG job. I don't recall doing mine when I did that job. Which was back in 2014.
Old 03-02-2023, 04:54 PM #41
Speedy's Avatar
Speedy's Avatar
Yeah, I'm ordering all new everything. Parts are pretty cheap and I don't wanna have to do it again for a while. Gaskets, tube seals, half moons, cam plugs, pcv gromet, fipg, valve cover bolt gromets, all in my cart.
Old 03-02-2023, 05:25 PM #42
Real Name: Patrick
Real Name: Patrick
Book time is a professional mechanic with power tools and a wide variety of tools to best get the job done. If John Doe only has a 102 piece craftsman kit with hand ratchets it's going to take a lot longer. Especially if they don't really know the steps and have to keep going on youtube to watch the video or reading a write up on a forum.
Old 03-02-2023, 05:27 PM #43
Speedy's Avatar
Speedy's Avatar
Makes sense. I'm fortunate to have a good tool box with power tools etc so hopefully it won't be as big of a deal for mine. The cleaning and painting is gonna slow me down though for sure.
Just finished adjusting the suspension. That video will be live tomorrow. Getting that strut back in there even with the lbj disconnected was still a major PITA, I gotta be missing something on that one. Putting the lift on the truck originally was a pain in regards to the front struts.
Old 03-02-2023, 10:29 PM #44
JoeT4R's Avatar
JoeT4R's Avatar
I will say that when I did that job, I had assistance from a friend. It was almost 10 years ago but if I recall correctly it took us about 4 or 5 hours and we did it in the street. All hand tools.
If I were doing it alone, I think the part that would hold me up the most is getting stuff disconnected and removed and reinstalled. I'm very careful with that kind of stuff. Overall it's not a horrible job. But you know what is?
Timing belt and water pump. Had a near and dear friend's Dad do the job for me while I assisted and learned. Took every bit of 10 hours start to finish.
Old 03-02-2023, 10:47 PM #45
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What took us the longest on the last engine valve gasket project. Was cleaning the gasket surfaces. It's not the easiest to get to everything with the engine in.
While the valve pans are off:
If you are around 250 to 300k is to check the valves for adjustment. It's enough time that your exhaust valves to get too tight and possibly the intake out of spec range.
As long as the valves are in that tolerance range. They are good. If you try to get them exact. It's possible, you be there for a few days .
Its just a thought while your in there.
fluid , miles , rear , recondition , replaced
My better late than never build thread gm350reratliff 4th Gen T4Rs 118 09-06-2022 12:19 AM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
