Old 01-28-2024, 07:20 PM #361
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Almost a year to the day since I started this thread and the truck is basically finished. Everything's reassembled and it turned out awesome.
Flare install video with parts needed and all that in 3rd post.
Speedy is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 08:07 AM #362
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
What a beautiful rig Speedy. I know that thing has been meticulously maintained and that's what makes it so much more sexy!!!
Old 01-29-2024, 01:26 PM #363
Speedy's Avatar
Speedy's Avatar
Thanks man. Super happy how it all turned out and am just enjoying driving it now. LOVING the heated seats, I shoulda done that years ago.
In other news.....here's the replacement for my stolen car. Showed up Tuesday.
Dodge Demon 170. 1025 horsepower right off the showroom floor. After my Hellcat was stolen I got a surprise call that made this happen. I feel humbled and blessed to get it, now I just need to get over the PTSD of mine being stolen and enjoy it.
Old 01-31-2024, 02:14 AM #364
partylikeit's1999 partylikeit's1999 is offline
partylikeit's1999 is on a distinguished road
Very Cool!
partylikeit's1999 is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 06:19 PM #365
Speedy's Avatar
Speedy's Avatar
A little update and aggravation. Back when I started going through the 4Runner to restore it, I had a rear axle seal leak on the driver side. I intended to do all that myself and tried to find a local machine shop, or other, that could do the press work for me to no avail. I ended up having Toyota just do both axle seals, wheel bearings, and rear brakes. I couldn't justify buying the press and SST that I'd use one time vs the price I could have Toyota do the job.
Well, the passenger side started leaking a little while later. They replaced it again. Now 6 mos later, it's leaked AGAIN. This time they're having a "more experienced" tech make the repair. Ummmm ok.
Anyway hopefully they get it right this time and highlights why I hate to have someone else work on my cars.
They gave me a 2023 4Runner SR5 as a loaner. I am NOT impressed at all. I'm surprised these even sell. Way under powered, worse gas mileage than my 2002, no better towing capacity, interior looks like it was designed by a 5 year old. Just an awful vehicle IMO.
Apologies to anyone that has one of these
Old 04-26-2024, 07:39 PM #366
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
Funny, my seals where my justification for getting a press
I did do the greased retaining ring flip-thing and they have held up for a few years,
but need to bear in mind the original orientation held for 20...
a GOOD WARNING to others to extend your breathers!
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 07:49 PM #367
Speedy's Avatar
Speedy's Avatar
Speaking of extended breathers.....
Old 05-08-2024, 03:32 PM #368
Speedy's Avatar
Speedy's Avatar
Update, it seems the original tech used a torch to remove the retainer and abs ring from the axle. Some "slag" or metal spatter from cutting the rings off got on the axle, and when the new rings were pressed on the slag cut a grove under the retainer ring causing the leak. All new rings, axle seal, wheel bearing, etc installed.
I've checked through the abs sensor on the axle and so far no leak. Hopefully that's the end of it but I'll continue to monitor.
Old 05-14-2024, 03:53 PM #369
Speedy's Avatar
Speedy's Avatar
Driving to Mom's Sunday going over bumps I heard a bang bang and felt a jar in the cab. Inspection showed one of my Energy Suspension front sway bar brackets that hold my Addco sway bar had broken in glorious fashion. No idea how, but it basically shattered on the front edge and bent down about 2 inches from the sway bar.
Quick stop at the auto parts place for two new Energy Suspension 1.25" sway bar brackets with bushings, and a stop at the hardware store for $20!! in grade 10.9 bolts, washers, and lock nuts and it's back to business. 4 bolts, 4 lock nuts, and 8 washsers....$20...w0w.
Old 05-17-2024, 11:01 AM #370
JoeT4R's Avatar
JoeT4R's Avatar
Pics or it didn't happen! Lol, just kidding. What a pain in the neck but fortunately it wasn't anything critical.
fluid , miles , rear , recondition , replaced
My better late than never build thread gm350reratliff 4th Gen T4Rs 118 09-06-2022 12:19 AM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
