Old 01-26-2023, 01:14 PM #1
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Better Late Than Never Build Thread
Are build threads still a thing? Anyway, I recently went through several and they were a big help so figured I'd throw one up on my 3rd gen. I've had it 20 years now so I'm probably forgetting some stuff. I call it Project SportRunner. It has been one of my all time favorite vehicles and in the 20 years I've owned it I have only had to make two repairs - one oxygen sensor and one rear axle seal leak.
A lot of the work I've done is on my Youtube channel: Speedy's Garage - YouTube
and my website: Speedy's Garage
To keep it short:
Bought a 2002 Xterra brand new. Nissan is local and through friends and family I got a huge discount. I wanted a 3rd gen 4Runner but couldn't really afford it at the time. I hated the Xterra and looked for a 3rd gen after a year of ownership. Found a low mile (10,000) used 2002 SR5 4WD 4Runner at a local dealer and traded the Xterra in on it. I couldn't believe this SR5 had leather. I loved it from the first drive. It was a Certified Toyota which came with a 100K mile bumper to bumper warranty if I remember correctly. Never had to use it though.
I've had it 20 years, so I'll try to remember all I've done.
How I got it in October 2003 with 10,248 miles
How it sits as of January 2024 with 158,246 miles
Performance
Detroit Truetrac installed in the rear
TRD Supercharger Stock Pulley, 2.2 Pulley, 2.1 Pulley
URD 7th Injector (only used way up in the boost range due to water/meth)
Kept stock fuel pump
Water/Meth Injection (highly recommended) custom mix using -20 washer fluid and HEET
Tuned by yours truly
Deck Plate Mod
AFe dry air filter
ISR Removal
Addco Sway Bar front and rear
Tundra Brake Upgrade with Power Slot rotors
Stainless brake lines
Transmission Cooler
(no valve body changes, no converter changes, stock fuel pump, etc)
Trans has been fine for 15 years and over 100K miles on this setup
This is BEFORE the 2.1" pulley or water/meth injection that allows me to run around 7° more timing
Suspension
Bilstein Tundra 5100 shocks front/rear
Tundra TRD Coils up front on the first second shock perch OME 906 Rear
Gave right about 2" 2.5" of lift on my 2002 SR5 4WD on the front and 2.5" in the rear
Hub to center front 21.5" 22"
Hub to center rear 22.25"
Tires Bridgestone Revo 2 265/75R16 (that are shot with 60K miles on them)
Toyo Open Country AT3 265/75R16
No diff drop, no torn CVs in over 100K miles with this setup
Exterior
Ivan Stewart TRD Wheels Level 8 MK6 16x8 0 offset Gunmetal Wheels
Factory Sport Hood painted to match
Sport skid plate
Removed factory running boards
Installed aftermarket tube steps custom powder coated gun metal
Satoshi Grill
Supercharged badging
Factory fog lights with factory stalk on the column (wiring was already there) rewired to work with parking lamps.
Motorized antennae failed (twice) replaced with Tacoma fixed antennae
HID retrofit headlamps with amber LED bezel rings and strips, bezel rings and strips wired to parking lights
All bulbs replaced with LED with adjustable relay for turn signal speed
LED Updated tail lights
Interior
Custom gauge panel and bezels for water/meth control and boost, AFR, trans temp. I had Autometer put green LEDs in the trans temp gauge to match factory dash a long with a dimmer to match illumination.
Gauges have bezels that aim them 10° at the driver
Green LED illuminated cup holders wired to come on with parking lights
Front/rear foot well lighting when doors open (bright)
Front/rear foot well lighting when parking lights are on (dim)
Updated head unit for bluetooth connectivity with mic for phone calls
Hard wired radar detector currently Uniden R3
Major Maintenance
Lots of oil changes
Spark plugs replaced 3 times currently running NGK Iridium
48,000 Miles 4/2006 - Lower ball joints replaced under SSC 50J Recall
60,000 Miles 1/2007 - trans fluid exchange service with Mobil 1 ATF, diffs/xfer case drained and filled with Mobil 1 75W90 synthetic, fuel filter changed
95,000 Miles - 10/2013 flushed brake fluid and replaced with Valvoline synthetic
148,000 Miles 3/2022 - Rear axle seals and rear wheel bearings replaced, rear brakes replaced, and axle retainers installed inverted to avoid future axle seal leaks.
149,000 Miles 4/2022 - Timing belt, water pump, all associated pulleys, radiator, t-stat, upper/lower radiator hoses, coolant flush/fill, all drive belts replaced including supercharger using all Toyota OEM parts.
153,000 2/2023 - Lower Ball Joints replaced for the second time
153,465 2/2023 - Diffs, Xfer case, Transmission, and power steering fluids all changed and cleaned power steering reservoir.
153,804 4/2023 - Valve cover gaskets, half moons, cam plugs, spark plug tube seals, and PCV grommet replaced. Painted valve covers wrinkle red. Cleaned AFE air filter. Changed supercharger oil. Cleaned throttle body.
154,443 5/2023 - Detailed cleaned and painted all undercarriage items, skid plates, spare wheel, suspension, and chassis and replaced any bolts that didn't look great with new ones. Used anti-seize on new bolts.
155,720 8/2023 - Custom Katzkin leather installed with heated seat elements.
157,248 11/11/23 - Full detail, decon wash, fallout remover, clay bar, paint correction, ceramic coating applied, restore and repaint fender flares
Upcoming Projects
Rear axle seals, rear wheel bearings, rear brakes Complete 3/2022 148,359 miles
Timing belt, water pump, associated pulleys/idlers, and all accessory belts including supercharger Complete 4/2022 148,632 miles
Replace radiator, thermostat (170°), upper/lower radiator hoses, coolant flush with Toyota coolant Complete 4/2022 148,632 miles
Replace lower ball joints Complete 2/2023 153,285 miles
Adjust TRD/Bilstein suspension Complete 2/2023 153,285 miles
Replace rear sway bar end links Complete 2/2023 153,285 and reused original front end links which worked great with the lift
Alignment Complete 2/2023 153,340 miles
New tires Toyo Open Country AT3 Complete 2/2023 153,403 miles
Diff/Xfer case fluid change with Mobil 1 75W90 / upgrade front diff plugs to Lexus with nut instead of hex Complete 2/2023 153,465 miles
Trans fluid exchange with Mobil 1 ATF Complete 2/2023 153,465 miles
Power Steering fluid exchange with Mobil 1 ATF / clean PS reservoir Complete 2/2023 153,465 miles
Replace fuel filter
Clean AFe air filter Complete 4/2023 153,804 miles
Valve Cover Gaskets Complete 4/2023 153,804 miles
Paint Valve Covers Complete 4/2023 153,804 miles
Change supercharger oil Complete 4/2023 153,804 miles
Clean throttle body Complete 4/2023 153,804 miles
Detail engine bay Complete 4/2023 153,916 miles
Paint frame and chassis Complete 5/2023 154,443
Recondition bumpers Complete 5/2023 154,443
Recondition trailer hitch Complete 5/2023 154,223
Recondition spare tire wheel Complete 5/2023 154,223
Recondition all skid plates Complete 5/2023 154,223
Recondition arm rest/console cover Complete 6/2023 154,989
Install new leather steering wheel cover Complete 6/2023 155,078
Replace Gauge Cluster Lens with new OEM Toyota Complete 7/2023 155,680
Recondition leather seats (maybe custom Katskinz?) Complete custom Katzkins with heated seats installed 8/2023 155,720
New OEM 4Runner Carpet floor mats Complete 8/2023 155,720
New OEM rear hatch struts Complete 8/2023 155,720
New Front Extended Sway Bar End Links Complete 9/2023 156,940
New Steering Rack Boots Complete 9/2023 156,940
Fresh Paint in Solar Octane or Inferno Orange? Cost prohibitive, re-paint was more than vehicle value. Going with plan B.
Full Detail, Decon Wash, Fallout Remover, Clay Bar, Paint Correction, Ceramic Coat Complete 11/11/23 157,248
Restore and Repaint Fender Flares Complete 11/11/23 157,248
Some Kind of Graphic Complete 11/11/23 157,248
Black out badges Complete 11/11/23 157,248
Extended Rear Diff Breather Complete 11/11/23 157,248
Speedy is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 01:14 PM #2
Speedy's Avatar
Speedy's Avatar
Old 01-26-2023, 01:14 PM #3
Speedy's Avatar
Speedy's Avatar
Restoration projects started 2/2023
Lower Ball Joints on a scale of 1-10 about a 3.
Adjusted the Bilstein suspension This was a difficult job in terms of getting the struts back in. Scale of 1-10 an 8 for me.
I was curious how the alignment would look after replacing the lower ball joints. Verdict is in, I definitely recommend an alignment.
Made the decision on the tires.
Getting ready for some fluid change, I built a DIY fluid transfer pump.
Diffs and Transfer case fluid changes
Trans fluid changed and it didn't look bad for 100K miles and 15 years
Power steering fluid changed for I think the first time ever, and it looked.....WEIRD.
Started on the valve cover gaskets. Removal. Scale of 1-10 about a 3. Just tedious.
Got the valve covers restored. Changed the supercharger oil, cleaned the throttle body, and AFE air cleaner while I was there.
Valve cover gasket job complete. Pretty easy, I still say a 3 or so on a 1-10 scale. I'd suggest doing it over two days so you can take your time.
Cleaned up the engine bay. I wanted to make sure I didn't have a rear main seal leak.
Starting to tackle the under carriage and went after the tow hitch first.
Got the chassis cleaned up, wire wheeled, painted, and replaced a bunch of grungy bolts.
Started work on the interior with the new arm rest and new steering wheel cover.
Replaced the scratched and blemished gauge cluster lens and polished the original to keep as a spare.
Installed new leather interior, heated seats, hatch struts, and floor mats.
Always triple check suspension clearance when you adjust it. I missed something and had to make a repair.
Flares removed, prepped, and painted.
Installed some graphics.
Flare Install and Re-Assembly
Old 01-26-2023, 01:49 PM #4
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
YES DUDE!
Sent from my SM-S908U using Tapatalk
Old 01-26-2023, 02:47 PM #5
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Glad to see you're making one, that thing is a beast!
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 06:34 PM #6
connorms's Avatar
connorms connorms is offline
connorms will become famous soon enough
connorms's Avatar
Surprised you didn't have a build thread already! I remember following your video when I did my first retrofit and have always been in awe at how thoroughly and cleanly you install everything. Your channel is the first place I go if I need inspiration on doing a project the "right" way lol. Glad to see you're starting a thread on here!
Long travel '97 Limited - build thread
connorms is offline   Reply With QuoteReply With Quote
Old 01-26-2023, 06:37 PM #7
Speedy's Avatar
Speedy's Avatar
Thanks for the kind words, it's been a lot of years maybe I had a build thread and forgot
Old 01-26-2023, 09:42 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nice build thread. Mine is mostly just frame repairing and maintenence things.
Old 01-29-2023, 11:26 PM #9
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Nice build thread and great looking T4R. What tube steps are those?
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 12:08 AM #10
drey6's Avatar
drey6 drey6 is offline
drey6 is on a distinguished road
drey6's Avatar
Speedy's Better Late Than Never Build Thread
Are you running the trans cooler in series or solo? Fan or no fan on the cooler and what model?
drey6 is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 02:43 AM #11
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Nice to see your build thread! I have watched all your 4Runner videos and appreciate all of your thorough and precise expertise with the work you performed in those videos. VERY helpful.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 11:44 AM #12
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
One of my favorite builds and I follow your YT channel
Old 01-30-2023, 02:00 PM #13
Speedy's Avatar
Speedy's Avatar
Trans cooler is in series. No fan. I believe it's a Hayden. Box said Tru-Cool and it was a 4454 model. This looks like it might be the replacement: Amazon.com: Hayden Automotive 678 Universal Rapid-Cool 9.5” x 11” Add-On Transmission Cooler – Not for Direct Replacement of the OE Cooler : Automotive
Mine has a bypass so that fluid doesn't go through it until it hits a certain temp supposedly.
They were some knock offs I found years ago after Toyota quit offering the tube steps. Mussa I think was the brand. They came painted with cheap black paint and I sent them off to a powder coater for a proper finish.
Thanks for following a long!
Thanks!
Old 02-23-2023, 06:20 PM #14
Speedy's Avatar
Speedy's Avatar
Time to get busy...
Old 02-23-2023, 10:28 PM #15
4x3Lander's Avatar
4x3Lander's Avatar
Cool! I will be watching this when it is out!
fluid , miles , rear , recondition , replaced
My better late than never build thread gm350reratliff 4th Gen T4Rs 118 09-06-2022 12:19 AM
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
