Old 01-27-2023, 05:25 PM #1
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Replacing Driveshaft Grease Zerk with Bolt?
So I finally broke the Grease Zerk off of my Driveshaft from hitting the Gas Tank.
I knew it was a possibilty, and after bending a rear control arm, it happened.
I was giong to just replace the zerk, but with my Panhard correction, it's going to keep coming close to the tank.
I planned to just drill/tap the fitting and replace with a button head bolt. That way it won't snap off again if I bend something and cause interference with the fuel tank again.
Thoughts? I have already trimmed as much of the fuel tank skid as possible. At this point, its actually hitting the metal tank.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 06:02 PM #2
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Could you just leave the zerk out for normal operations and screw it in whenever you want to grease it, then remove it again? Kind of a nuisance but it's a thought, right?
Old 01-27-2023, 07:10 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
For what it's worth, zerk fittings aren't unique thread sizes, so if you can work out what threading the zerks are you should just be able to buy a bolt or plug which is the correct threading already instead of trying to drill and tap it.
Skulking is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 09:00 PM #4
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
I used a small metric button-head cap screw to do what you are referring to.
I got it from a Thule rivnut package for putting C-channel track into sheetmetal.
My hooptie tap & die set specs it as an M5 0.8 thread if that helps?
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 01-27-2023, 09:41 PM #5
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
The zerk is basically just a bolt anyway so it won’t hurt anything. There are some ball joints I have seen that have bolts to plug the grease holes - you take them out and install a zerk or other fitting temporarily to grease it.
JZiggy is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 09:18 AM #6
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
I loctited a set screw there and keep a zerk in my toolbox for when it needs grease.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 11:47 AM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
When you get a lift from Sonoran Steel, he includes a small button head bolt to replace the rear slip yoke zerk fitting for the exact reason you are. So yes, it's been done by lots of people. Nothing new.
You should be able to back out the broken zerk with an easy out. No need to drill and retap. Just match up the size thread and pitch and get yourself a small button head bolt. Easy Peazy.
Old 01-28-2023, 12:47 PM #8
The jobber boxes at some autoparts or hardware stores should have those zirc plugs with the zerc fittings.
Old 01-28-2023, 03:38 PM #9
JoeT4R's Avatar
JoeT4R's Avatar
I actually have a bag of zerks in my toolbox. I'm not 100% sure but I think somebody on here sent me them via mail sometime last year or the year before. If you want, I can take a picture of them and if you need one or multiple I will be happy to send whatever you need to you. Just let me know.
Old 01-30-2023, 12:37 AM #10
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
What about one of those low profile needle type zerks? They make some that barely protrude. I've seen even lower profile ones than this in the past.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 10:31 AM #11
shadow247's Avatar
shadow247's Avatar
That looks like it could work...
I will definitely be doing something in the next few weeks. Its coming up on time to grease everything again.
The 4Runner Show
Old 01-30-2023, 10:38 AM #12
thezentree's Avatar
thezentree's Avatar
If you're wiping a normal zerk off the driveshaft, the head of that will probably get removed as well.
I'd be really interested to be proven wrong though.
Old 01-30-2023, 10:44 AM #13
JZiggy's Avatar
JZiggy's Avatar
I installed these sintered filters in place of my slip yoke zerks. Lower profile and will allow air to move both directions so there's no buildup of positive or negative pressure.
I realize they are out of stock on Amazon but I'm sure they can be found somewhere
MettleAir BBV-M6 Flat Pneumatic Muffler Filter, Sintered Bronze, M6 (Pack of 10): Amazon.com: Industrial & Scientific
Old 01-30-2023, 03:57 PM #14
Depending what clearance you have they also make a low profile 90 degree fitting. I needed those for the Lower Ball Joint on the D60 front axle to clear the u-joints.
Old 01-31-2023, 09:23 AM #15
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
This is what I'm running on my rig not for interference issues but because Jziggy was so generous enough to send me an extra one he had for free.
Works great! Thanks again.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
driveshaft , fuel , replace , tank , zerk
Rear driveshaft zerk Chuckles89 3rd gen T4Rs 16 07-07-2017 09:41 PM
LBJ Grease Zerk Co4Fun 3rd gen T4Rs 51 02-08-2017 06:19 PM
Grease zerk info on front end Mindomission 3rd gen T4Rs 4 08-04-2014 09:46 AM
Replacing broken driveshaft zerk mcaz5 3rd gen T4Rs 6 09-29-2013 10:44 PM
