Old 03-01-2023, 09:16 AM #61
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Langcow1 View Post
It’s running great now. It could just be in my head but it seems like it has more power since I switched the Denso sparkplug wires to NGK
You have more power because all your injectors are working properly.
Old 03-01-2023, 11:32 AM #62
Daryl Elmore Daryl Elmore is offline
Daryl Elmore is on a distinguished road
Slothy, I had the exact same symptoms as you, rough cold start, clears after a few seconds. Also had smoke out of the exhaust during startup but its cold here in Idaho so that may have been the cause. after a compression test and testing the coolant for exhaust gasses #4 was down to 165 and the others were all 185-200 so I pulled the left head. End result was 2 cracks between the valves which seems to be not uncommon. New head and gaskets and she's back running great. When I pulled the head, #4 piston was clean compared to 2 and 6 which was the dead giveaway coolant was getting in.
Daryl Elmore is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 06:27 PM #63
Sparman Sparman is offline
Real Name: Curt
Sparman is on a distinguished road
Real Name: Curt
I have the same experience as Daryl, except my problem was a head crack between the valves over the #3 cylinder. It really wasn't a tough job. If you've done a timing belt job and valve cover gaskets, you've covered 80%+ of the job. Other than that, it's removing exhaust manifolds and heads. Plan your parts list, set aside two full weekends, watch Tim's videos and Chigger's videos, and you can knock it out.
Sparman is offline   Reply With QuoteReply With Quote
Old 03-12-2023, 04:19 AM #64
Langcow1 Langcow1 is offline
Real Name: Matt
Langcow1 is on a distinguished road
Real Name: Matt
😄 Yep definitely better than when it was misfiring! I wonder though if it was subtly failing for a while before the misfire started and I was losing a little power from it. It definitely feels like more power now than before the misfire, so it’s either that or the Engine Restore additive really had a positive effect.
Today I finally got the crusty old fuel filter changed. That seems to have made a positive impact too but how much I can’t say.
1999 SR5 manual 4WD; 300,000 miles!
Langcow1 is offline   Reply With QuoteReply With Quote
Old 03-30-2023, 08:48 PM #65
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I feel like I have the same issue as I'm starting to have the same symptoms. Going to confirm it here soon with a leakdown test and coolant system pressure test. If my compression test comes back good i'll probably just replace the head(s) if it's cracked. Does anyone have a good place to recommend getting new heads at?
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 02:35 PM #66
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
There are not any brand new cylinder heads outside of Toyota that I'm aware of due to the complicated process of casting and manufacturing cylinder heads. There are some high quality remanufactured/refurbished cylinder heads such as Yota1's product here at a rather decent price:
5VZ OEM 3.4 Reconditioned Cylinder Head 95.5-04 - Yota1 Performance, Inc.
Outside of them, honestly your best bet is pulling one off an old junkyard unit, buying new valves, springs and seals and sending it to a machine shop for assembly and testing.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 04-01-2023, 04:12 PM #67
mudbug87 mudbug87 is offline
mudbug87 is on a distinguished road
Welp! It looks like my head gaskets have gone too. Whats weird is that when I did a leak down test cylinders 3 and 4 resulted in a geyser from my radiator. The rest of the cylinders were great.
Is it common for the gasket to go out on both sides of the engine? Also does anyone have a sense for how common it is for the gasket to go out vs a cracked head?
I have never over heated the engine and overall it runs like a champ.
PS sorry if this is thread high jacking, but I dont have the privileges to make my own post yet.
mudbug87 is offline   Reply With QuoteReply With Quote
Old 04-01-2023, 04:28 PM #68
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It can happen. See if you can rent a botoscope or buy one that attaches to a cell phone and look in the cylinders you know are bad.
Why it's not as noticeable is both cylinders are directly across from each other and kinda balancing the loss out.
Old 04-01-2023, 10:16 PM #69
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
@infamousRNR and I will be working soon on a head gasket video series. Stay tuned.
Old 04-03-2023, 03:07 PM #70
Real Name: Jerod
Real Name: Jerod
It's more common for the gasket to fail as it is a weaker failure point than the aluminum heads. However it is good practice to have the heads pressure tested and milled flat at a machine shop (less than $100 per head) before reinstallation and they will tell you if it's cracked so you don't accidentally put a bad head back on.
326WHP 347TQ
air , motor , rebuilt , replacing , yota1
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
bad head gasket, fix or motor swap, want to keep manual trans rexassian 3rd gen T4Rs 46 02-04-2020 01:15 PM
Replacing Head Gasket on High Mileage Motor PhdNPrerunners 3rd gen T4Rs 16 08-02-2018 02:53 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
