Old 01-29-2023, 09:50 AM #1
slothy49 slothy49 is offline
slothy49 is on a distinguished road
Head Gasket/Head vs Rebuilt Motor
Just bought an 01 4runner with 260k on it. It’s in the very early stages of the head gasket blowing. Wondering if at this mileage I should just shoot for a rebuilt 5vz motor?
Cylinder 3 misfires only very briefly on a cold start. Stops after 3-5 seconds. Getting air bubbles through the radiator on cylinder 3 leak down. Small amount of air coming through the oil cap filler on the other cylinders on leak down (leading me to think piston rings are getting worn), and about 10-20% loss across all cylinders. Doesn’t overheat at all. Coolant temp sits at 190-205 all day.
With the age of the motor would replacing motor be a better gamble than just replacing the head/head gasket? If so is there anywhere other than yota1 that can provide a quality rebuilt. Yota1 is pushed out 7-8 months. Brother is a mechanic and we have access to a shop so labor is not the biggest concern. A reliable truck is.
slothy49 is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 11:25 AM #2
If the compression is in spec I’d just do the heads. Look for a motor or a rebuild at your leisure.
Rebuilt heads can then be transferred to a reman block later. All you will need later is a “short block”.
Old 01-29-2023, 12:13 PM #3
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon will become famous soon enough the_welfare_wagon will become famous soon enough
Real Name: Rich
I had a head gasket failure at 278k. Turns out the block was pitted around the water jacket due to crappy coolant(I assume) and that was why it blew. I smeared JB weld in the pits and sanded it down even to with the block, copper sprayed the head gasket and torqued that sum***** down.
Had no time to rip the block to get it milled and the pits were too deep for that to even do anything.
Why am I telling you this? Cause almost 100k later the motor is still running fine and uses no coolant. I did purchase new heads but If I can JB weld my block and get another 100k then you’ll definitely see at least as much as long as the motor has been cared for and continues to be
96 Limited: 380k+ 255/85s Geolander MTs, Ironman Nitro 2" lift, Toytec 9602HD W/FJZ80 Shocks
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 03:41 PM #4
Need to do a compression check still. What are good numbers for compression on these? Even with the air coming through the oil filler, probably worn piston rings or worn heads, you'd do the head gasket and head before going straight to rebuild? Thank you!
Old 01-29-2023, 04:29 PM #5
If your compression isn’t out of spec redoing the head gaskets with reman heads will buy you time. Then all you need to buy is a short block and put your good heads on the short block.
My one friend has an engine shop so I had him rebuild my spare engine with a bad HG at 258k miles.
Old 01-29-2023, 05:15 PM #6
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
If it was me, I'd find a new engine and forget about it for another 300k miles.
A complete JDM low mileage engine is only $2300 ish.
No brainer.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 05:49 PM #7
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I'm gonna +1 the above. If you have the time, money and resources, why not try a JDM engine? If you can afford to have the truck down for an extended period of time, I see that as an ideal project opportunity.
Old 01-29-2023, 06:10 PM #8
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What happens when the JDM engines are no longer an option? As they quit selling 4 runners in Japan in 2009. It's just a matter of time before inventory us gone.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 01-29-2023, 06:31 PM #9
JoeT4R's Avatar
JoeT4R's Avatar
I suppose we'll have to rely on the inventory of local junkyards here in the U.S. And if that isn't an option one day, then maybe it's time we move onto greener pastures, lol.
Old 01-29-2023, 07:55 PM #10
Taco’s had that engine into the mid 2000’s some time as an option.
Old 01-29-2023, 08:06 PM #11
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Very few if any of the jdm engines are coming from a Hilux surf/4Runner, and they put the 5vz in a ton of different vehicles so I don’t think there will be a shortage of engines for a long time, and even when that time comes there are so many of these engines floating around I think the aftermarket will provide all the parts needed to keep rebuilding them
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 01-29-2023, 09:31 PM #12
No brainer.
I've read a lot of horror stories of the JDM engines having completely false mileage claims and shady histories. Seems like a big gamble. Even if they post compression numbers who's to say they send me the engine those compression readings came from.
Old 01-29-2023, 09:33 PM #13
If compression is good on the engine, and we rebuild the head, who's to say the engine won't last another 250k? Without replacing the short block. If compression is bad, I'll definitely look into sourcing a short block, but if it's good should I even bother with a short block for now?
Old 01-29-2023, 10:54 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
These engines are not known for ring issues. These have cast iron blocks (V6)
You are seeing people going over 500K plus on these rigs with minor issues.
The 4 cylinder is mostly doing quite well too..
What kills these engines is the lack of maintenance. No oil changes and the big one... Getting the heads hot. You take any Toyota engine up to or Past H. You are going to do aluminum head damage. This has been an issue way back into the 80s and 70s.
My point was that JDM is a gamble just like any junk yard engine would be.
(people lie )
I was hoping that a few other engine re builders would be listed. I only seen one listed here and are backlogged. So I guess folks will have to find a local engine re builder or do it themselves.
Old 01-30-2023, 07:59 AM #15
JoeT4R's Avatar
JoeT4R's Avatar
This is also true! My Dad's 03 has the 5VZ in it as well. Super low mileage, too. Like maybe 140K at absolute most.
air , motor , rebuilt , replacing , yota1
Head Gasket or Cracked Head 02 4runner - Colorado any mechanics out there? vanderwiel 3rd gen T4Rs 9 09-26-2021 09:10 PM
bad head gasket, fix or motor swap, want to keep manual trans rexassian 3rd gen T4Rs 46 02-04-2020 01:15 PM
Replacing Head Gasket on High Mileage Motor PhdNPrerunners 3rd gen T4Rs 16 08-02-2018 02:53 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
