Old 01-30-2023, 03:49 PM #1
psea17 psea17 is offline
psea17 will become famous soon enough
Front Differential Swap
hello,
bought a '99 rear axle w 4:30 gears, grabbed the matching gear for the front. decided i wanted a front elocker so i grabbed a new one from ECGS. had zuk set it up.
but i think i need an actuator for it, right? anyone know the part number? will it fit without modification or do i need to replace other parts? i only received the 3rd member, not any of the 'arms' or shaft that extend from it.
thanks in advance!
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 01-30-2023, 07:43 PM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is online now
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The actuator and diff tube would swap over from the diff you’re currently running. Did they do the needle bearing or ECGS bushing on the driver’s side in the newly setup diff? If not, now would be a good time to do so before you install it. Unless you’re of the mindset if it ain't broke, don’t fix it. It can wreak havoc if it decides to fail later on.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is online now   Reply With QuoteReply With Quote
Old 01-30-2023, 09:27 PM #3
so despite not having a front locking actuator on my truck now it will still lock using it? kind of surprised. happily so, but surprised.
are they all the same whether diff has a locker or not?
Manual Transmission
Old 01-31-2023, 01:24 AM #4
Real Name: Evan
Real Name: Evan
The stock actuator on your 4Runner’s front 7.5” clamshell is to engage 4wd, not the locker. You’ll swap whatever actuator is on your old front diff and the diff tube and once bolted up your 4wd will function on the newly setup diff. How you engage the e-locker is I believe what you’re asking? No 3rd gens came stock with a front locker or the associated wiring, so that is all aftermarket.
Old 01-31-2023, 02:38 AM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you got an e-locker from ECGS, I'm assuming it's an Eaton. You should have gotten a wiring harness and switch with it. If you need a tutorial on how to wire it up, here you go.
Old 01-31-2023, 10:54 AM #6
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Tim, how you liking the E locker so far?
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 11:49 AM #7
thanks timmy! i watched all of your videos...at least twice lol. would like to hear about your experience w your elocker.
on a slightly different note, can the front mounting arms be removed while the diff is still in the truck? i want to burn out those old bushings and replace them in advance of my buddy coming over to help me....so i can perhaps shorten a long day? think it will be harder for the diff to come out without those arms attached?...or little difference?
thanks for the input guys! it's ALWAYS much appreciated.
Manual Transmission
Old 01-31-2023, 12:18 PM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
The Front diff arms can be removed without taking the whole diff out
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 01:57 PM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I haven't gone wheeling to test it out yet, so I can't really give a review.
Old 01-31-2023, 01:59 PM #10
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yeah Dude, they can. I thought you watched all our videos at least twice. Maybe you fell asleep during this one.
Old 01-31-2023, 03:46 PM #11
lol. didn't know there was a specific video just for that!!! another 2 views incoming
Manual Transmission
extend , front , grabbed , part , replace
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Transmission Swap or Differential Swap: Two hurting 3rd Gen T4R SteelRunner 3rd gen T4Rs 12 09-10-2014 11:00 PM
HELP! Differential flange swap - how do you do it? RPS13 4th Gen T4Rs 14 11-30-2013 08:05 AM
differential swap mrgomez 3rd gen T4Rs 6 05-08-2013 05:07 PM
Rear differential swap? 10gaOkie 3rd gen T4Rs 15 08-03-2011 08:22 PM
