Old 01-31-2023, 07:54 PM #1
lpsoldia311 lpsoldia311 is offline
lpsoldia311 is on a distinguished road
Crank Pulley Wobble
I read up on the previous threads on this for this generation 4R and in most cases it ended up with most people saying or finding out they had a loosened/broken bolt and/or busted pulley where it separated at the rubber connections. In every case I've not really seen what they considered wobble that was severe enough to be concerned about and/or how bad the wobble was. It's a 2000 SR5 5VZ with 275k miles on it.
I just did the most recent timing belt/water pump a couple hundred miles ago; this is the 3rd time I've done this job on this type of engine, 2nd time I've done it on this particular 4Runner, last time was at 185k with no issues) and was crawling under it to fix a rattle while engine running and noticed the pulley section itself (not the main section) seemed just slightly wobbly but not throwing the belt around really. Just enough to never remember it being like that honestly but not enough to definitively say something's not right as I rarely have to crawl under it and be directly under the crank while running.
Now I'm questioning if something is wrong. I would've thought the same thing as others in that my bolt came loose but the key and keyway looked perfectly fine when I removed the pulley for the timing belt job and slid back on perfectly fine. I torqued the same bolt to 217 ft-lbs without issue with a cal'd torque wrench just as last time; it's the larger version that calls for the higher of the two torques. Would approximately 1/8" of runout on the front of the pulley face be cause for concern? I.e. if I put a tape measure to the front of the pulley face and extended it towards the front of the car my best estimate is about 1/8" difference at worst. Now that i watch the video I guess it just looks like a lot more wobble from underneath when it's 12" from my face than from up top.
My father in law mainly drives this locally now so not really too worried about being stranded but wondering how many people have an actual slight wobble but just never noticed it until things started banging around/running rough.
Video:
https://streamable.com/9haakk
lpsoldia311 is offline   Reply With QuoteReply With Quote
Old 01-31-2023, 07:59 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like the rubber in the harmonic balancer is starting to fail
Old 01-31-2023, 10:58 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
A actually once ripped one of out just trying to get crankshaft bolt loose...:/
We got it by jamming the flex plate and using an 8ft pipe with a breaker bar with the engine on an engine stand. Somebody in its past really got carried away ...:/.
I used Dorman replacement harmonic balancer and they work well.
Old 02-01-2023, 09:03 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I would hate to see what happens if the pulley were to fail in operation. At best it throws the belts and you lose power steering. At worst it damages the crankshaft and your motor is toast. It is not supposed to have any runout so it seems a new pulley is in order. You could also put on a solid aluminum pulley like from LCE performance parts as I don't know crankshaft pulley prices anymore. It's not a harmonic balancer as the engine is internally balanced.
326WHP 347TQ
Old 02-01-2023, 10:33 PM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I'm pretty sure @Bad Luck gave you the right answer. The harmonic balancer is actually two separate pieces joined by a hard rubber. The torque value for the crank bolts is very high. If the aging rubber in the harmonic balancer can't handle the torque value, it could tear causing the wobble you're experiencing.
bolt , front , pulley , time , wobble
Crank Pulley Nut mendozer 3rd gen T4Rs 20 07-07-2020 12:57 AM
JDM Crank Pulley Will Not Come Off! In Sac & Need Help gamefreakgc 3rd gen T4Rs 43 03-06-2020 08:18 PM
WTB 1st Gen Crank PS/AC Pulley Naked Runner Want to Buy/Trade 2 01-26-2016 06:46 PM
URD crank pulley GX4SEVEND 3rd gen T4Rs 4 07-20-2013 07:34 PM
Crank pulley prodigy2k7 Classic T4Rs 9 01-09-2008 05:42 PM
