Old 02-03-2023, 02:09 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Clean the MAF with only MAF cleaning solution in an aerosol can. Failure do to so will end up with nasty results. I always use brake cleaner or wd 40 to check for vacuum leaks those are easy to find being the engine will speed up when you hit the leaking area.
These are definitely old enough to have these vacuum lines cracking and splitting, especially the air intake pipes that come in from the air cleaner box.
Old 02-03-2023, 05:06 PM #17
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by Zhehan View Post
I have had this problem more than once myself. I ran into this issue last September after a super dusty trip through the forest. I know from experience to check the MAF first when this code pops up. The part of the MAF that needs cleaning is the little brown bulb that's exposed. The 2 thermistors inside it are the IAT sensor circuit. I usually just use a q-tip and some rubbing alcohol to gently clean the bulb. It should be shiny. If it's dirty, it will have a dull appearance.
Hops this helps.
Cheers.
This is interesting. It was my understanding the wires inside were what you needed to clean off because those are what read the amount of air coming through.
Old 02-03-2023, 08:17 PM #18
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Originally Posted by Skulking View Post
For anyone wanting to clean their MAF, this is a great example of how not to do it. Never use anything like a Q-tip which makes direct contact with the MAF to clean it, the sensor is very sensitive and can be easily damaged. Instead, use MAF cleaner which you spray on the sensor to clean it, and importantly will dry clean without leaving any residue on the sensor which can impact the readings.
Fine then!
Seriously though, I've never had an issue doing it this way...
But, noted that I'm doing it wrong.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 02-04-2023, 09:34 PM #19
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Fine then!
Ha, you got a lot of flak for something that actually doesn't hurt anything! The amber-like bulb isn't the mass air flow sensor wires, it's the Intake Air Temperature (IAT) sensor. You can clean it with a q-tip as it's not fragile unless you apply significant pressure. The exposed wires coming out of the top are just to relay the voltage change based on temperature. Having the slight haze of dirt on it isn't a big deal either way though as your intake air doesn't really change temperature all that fast.
The two very thin wires tucked inside of the sensor is the actual MAF sensor wires. As they are very thin and hard to access anyway, MAF cleaner is sufficient as they are out of the direct flow of air don't get dirty all that fast. Those are the ones that should not be touched under any circumstance.
There are some things to be paranoid about and others not. You're doing it just fine.
326WHP 347TQ
Old 02-05-2023, 01:40 PM #20
I guess I had it backwards then. But, if I just clean the dirty bulb, the code will go away. And, I associate a thermistor with temperature...
Old 02-05-2023, 01:44 PM #21
Sorry this picture is so crappy, but it's a million years old and a screengrab I believe. But, as you can see, it illustrates the Intake Air Thermistor in our MAF. That's probably the source of my confusion.
P0171 running lean-picture5-jpg
Old 02-06-2023, 01:55 AM #22
Real Name: Jerod
Real Name: Jerod
It's all good. Besides, with a steady hand a lots of care you can do some things that are not supposed to be done.
For example, you'll search all over the forums that our idle speed cannot be adjusted and it controlled by only the ECU. Well, I adjusted my idle and all it takes is a little time and patience. Though once the factory paint mark is gone I was on my own if I could ever get it back to the way it was.
Point is, you're doing maintenance on your rig and learning along the way. Nothing wrong with that at all. The MAF is only about $50 if it gets totally screwed up anyway.
326WHP 347TQ
amazon , issue , search , sensors , smog
How to Fix P0171 System to Lean Code speedgoat 3rd gen T4Rs 13 04-10-2022 04:33 PM
P0171 False Lean Firstborn10 3rd gen T4Rs 5 10-08-2019 11:44 PM
P0171 Code - Lean Bank 1... Help? jpontius 3rd gen T4Rs 5 02-23-2013 11:00 AM
P0171 Lean judoant 3rd gen T4Rs 9 07-05-2012 02:34 PM
P0171 (B1 System Too Lean) Rescue84 Problems & Warranty Issues 2 09-27-2006 03:47 PM
