Old 02-02-2023, 12:46 PM #1
greembow greembow is offline
Real Name: Kiwi
greembow is on a distinguished road
Real Name: Kiwi
Best place to mount auxiliary gauges?
Hi there, I've been wanting to add a digital oil pressure gauge to my rig for quite some time, but I can't find a good place to mount it. I've looked at the FlexPod from CravenSpeed, but I can't get over the price and the fact that it will probably block my trip mileage, which I use to figure out my remaining fuel, as my gas gauge doesn't work properly. Are there any other good places to mount a 2 1/16.
greembow is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 02:02 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
the best OEM way is to get some of the 1st gen tacoma a-pillar plastic trim pieces
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 02:08 PM #3
Spiker?
Gauge Mounts Archives - Spiker Engineering
You can do a dash-top phone mount and add a gauge mount, scangauge mount and add a 2 1/16 holder, etc.
Or if it something like a gas gauge (not something you need to see all the time, down below the radio on the left is a decent spot for a custom plate to mount a gauge.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-02-2023, 02:52 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Spiker Engineering has excellent products...
Old 02-02-2023, 03:36 PM #5
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Thanks for the shoutout guys . Here are a couple of installations to give an idea of how the gauges can be mounted:
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 05:22 PM #6
Real Name: Kiwi
Real Name: Kiwi
Haha! I already have your ultragauge mount! I didn't use it for an ultragauge, but I used it to mount my ICOM ID-5100A Deluxe Ham Radio! It works great! I'll look into the gauge mount from you!
Old 02-13-2023, 05:05 AM #7
MarinersFan95 MarinersFan95 is offline
MarinersFan95 is on a distinguished road
Timmy has a video where he installs a transmission temp gauge in a 98' and mounts the gauge in a little plastic housing thing that attaches to the driver side A-pillar. Looked pretty clean from what I remember, you should watch that video and see if that location would work for your needs.
MarinersFan95 is offline   Reply With QuoteReply With Quote
block , gauge , good , mount , place
Where in the trunk is there a safe place to drill in a air pump mount Mudballz 5th gen T4Rs 6 04-26-2020 07:56 AM
Creating a custom auxiliary battery mount ShaftedTwice 4th Gen T4Rs 0 12-20-2018 12:46 PM
Best Place's To Mount Your Guns In A 3rd Gen BootCampBuild 3rd gen T4Rs 75 01-02-2015 01:42 PM
Would this be a good CB antenna mount place? s-one 4th Gen T4Rs 10 05-19-2011 05:15 PM
Whats the best place to mount brake controller BigK75 4th Gen T4Rs 5 10-15-2009 07:40 AM
