Old 02-03-2023, 06:58 PM #1
JohnLocker's Avatar
JohnLocker JohnLocker is offline
JohnLocker is on a distinguished road
JohnLocker's Avatar
Having trouble removing the tow hitch exhaust is in the way.
I tried pulling the exhaust a bit, can’t get my breaker bar to fit. I got all the other bolt off easily but this one bolt is being a nut.
JohnLocker is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 07:17 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If you cant get in there. you may have to disconnect your exhaust at a flange and re-gasket it to get it off. If your exhaust is custom or all welded together, this can be a very bad situation.
How about a super short socket with extensions? They make 6 point wrenches with a bar on the wrench. Crows feet would probably just strip the head off.
So if you don't have enough room your best bet is that 6 point wrench with the cheater pipe on it. :-)
Old 02-03-2023, 07:30 PM #3
JohnLocker's Avatar
JohnLocker's Avatar
alright cause it’s oem i don’t have the tools/equipment nor do i have money to afford tools like that. I will be going to harbor freight tomorrow so a 6 point wrench with a cheater pipe i will definitely keep my eye out for one
Old 02-03-2023, 08:07 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I hear you. You just asked how to get it off...:-) Those are tight... I pull them off with impact sockets and high power impacts.. If that doesn't work I put a pipe on my 2 ft long breaker bar. I have actually snapped those heads off those in a rust belt here.
Being in CA, at least you wont have to worry its is rusted together. Look on the bright side. ;-)
I am not sure harbor freight will have them.. they might. Home depot has 6 point wrenches gear wrench 14 piece kit for $53.38 (probably different pricing around the country)
Looking like 18, 19mm is the largest wrench in that particular kit. Some auto parts stores like you rent or buy and return tools too..:-)
Old 02-03-2023, 08:42 PM #5
JohnLocker's Avatar
JohnLocker's Avatar
i’m in cali as well i have yet to break the bolt yet with my breaker bar. I know i need something flat. I don’t wanna strip cause i plan on selling it. I wanna turn my 4Runner into a project. So would just regular 6point wrenches work? cause i was using 17mm to remove the bolts?
Old 02-03-2023, 09:03 PM #6
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Did you try popping off the rubber exhaust hangers? That should drop the exhaust enough to get the breaker bar in there. All you need is some wd40 and a pry bar.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 10:35 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
17mm 6 point wench with a pipe on it really should get that bolt loose. :-) If it wont move, use a bigger pipe. Just make sure to keep that wrench on that head perfectly..
Old 02-03-2023, 10:48 PM #8
ED_96Ltd's Avatar
ED_96Ltd ED_96Ltd is offline
ED_96Ltd is on a distinguished road
ED_96Ltd's Avatar
Agreed with Twisted Syd^ spray some WD40 or some white lithium grease all over and inside (if you can) the rubber hanger and that's usually all that's needed to wrestle it off. Then a BUNCH of pb blaster on that stuck bolt before taking a cheater bar to it. Using a 6-point socket will be crucial in avoiding stripping it, in my experience at least.
'96 4Runner Limited - 327k miles
- OME 881/890, Bilstein 5100's, BFG KO2's (265/75/16)
'14 4Runner Trail Edition - 162k miles
- Diode Dynamics SS3 Fogs, XenonDepot DRL/High Beams, Cooper Discoverer A/T's
ED_96Ltd is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 10:51 PM #9
JohnLocker's Avatar
JohnLocker's Avatar
no i didn’t i can try that tomorrow i didn’t think it would come off
Old 02-03-2023, 10:53 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I was just going to suggest that.. Good thought. :-)
Old 02-04-2023, 07:51 AM #11
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd has a spectacular aura about Bassturd has a spectacular aura about
Bassturd's Avatar
Windex works really well on those rubber hangers dries quickly and won’t leave an oily residue like WD or PB blaster.
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 02-04-2023, 09:27 AM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good to know...
Old 02-04-2023, 10:09 PM #13
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
If those rubber hangers are original, you may never get them off. I had to replace the ones up near that cat once and the rubber had solidified and it was NEVER coming off. I had to cut them.
326WHP 347TQ
Old 02-04-2023, 10:23 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
In my case the hangers themselves mostly rust off...
Old 02-07-2023, 04:29 PM #15
JohnLocker's Avatar
JohnLocker's Avatar
Managed to take it off just had to remove those rubber mounts. Also if anyone wants it i’m selling it on Facebook marketplace and Offerup and Craigslist. It’s $135 right now. Lemme know.
bar , bolt , easily , exhaust , iphone
Trouble removing bumper shell on '07 ddnww 4th Gen T4Rs 3 02-24-2016 10:16 AM
Trouble removing Front Rotors with Pacer center caps 4RUNNERTMAN 3rd gen T4Rs 2 08-30-2015 12:35 PM
Trouble with exhaust Cmwise Classic T4Rs 4 12-23-2013 08:16 PM
Having some trouble removing bolts mcaz5 3rd gen T4Rs 2 08-13-2012 03:10 PM
Trouble removing starter from engine bay. Please help! Lugnutz 3rd gen T4Rs 9 08-09-2011 08:29 PM
