02-05-2023, 10:23 AM
Fast start when engine is warm
Before I go any further I have searched for answers on the forum. Some threads were close to my symptoms, but not exact. New battery, alternator, starters, battery cables
So when my engine is cold, it starts normal. Whenever I am running errands or traveling and the engine is at operating temp-it will start extremely faster than a normal cold start. Any thoughts? The mechanic I take it to is stumped and can’t figure it out. He said maybe an electrical issue
🇺🇸 2005 Limited v8, 255/75/17 Mastercraft MXT, ToyTec 3” Lift With Superflex Rear Springs, LED Interior Swap, 161,000 Miles 🇺🇸
🇺🇸 2000 Limited 3.4, 166,000 Miles, Bone Stock...Currently 🇺🇸
02-05-2023, 11:47 AM
Real Name: Jon
Real Name: Jon
The fuel pump will not tun o until it gets a signal from the crank position sensor so that's mostly a 1.5 to 2 second after engaging the starter at cold.
When hot the fuel pressure is probably already there and it starts faster taking less time to fire up.
Most vehicles turn the fuel pump on when the key is in the on position. The 3rd gen 4 runner waits for the signal before enabling as a safety feature.
02-05-2023, 12:06 PM
By faster do you mean it rev's higher than normal after a warm start?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
02-05-2023, 12:54 PM
Clean the Idle Air Control (IAC).
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
02-05-2023, 02:17 PM
If you just replaced the battery it may need to relearn it’s hot idle IAC position. It’s an adaptive parameter that goes to factory default when the ECU looses power.
Could be a dirty IAC also. What does the hot idle settle to after a hot restart?
02-05-2023, 07:27 PM
So I should look into the crank position sensor? Thanks for the info, I’ll do some research
02-05-2023, 07:28 PM
By faster I mean this. When engine is cold, it’ll take say 2 seconds to start or so. Whe engine is warm and operating temp it’ll start in like 1/4 of a second
02-05-2023, 07:29 PM
Will do, I’ll look into it and clean it when I get a chance. Thanks!
02-05-2023, 07:31 PM
This happened before I changed the battery as well. It’s been happening since I bought it 2 years ago. It’ll start every time no matter what, just super fast when warm. And when it’s warm, it’ll settle around 700rpm or so? I don’t drive it daily or actually much at all. Have a company car that I use every day
02-05-2023, 08:19 PM
Real Name: N/A
Real Name: N/A
I don't see the problem. It's normal for the engine to start easier when warmed up.
My 4runner will start almost immediately when I twist the key and the engine is warm. Takes longer when it's cold, but no more than a second even then. The RPM will be above 1000 at idle on a cold start and go down to 700 rpm. Everything your describing is normal engine behavior.
Do modern cars not behave this way anymore? Every car I've been in with a twist key has always started easier on a warm engine.
1998 4runner 2.7 manual
02-05-2023, 08:38 PM
Normal.
02-05-2023, 08:47 PM
Yea pretty sure this is normal. Mine does it and have always thought it was normal.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
02-06-2023, 05:17 AM
I thought you meant rev higher. Yea, this is normal.
02-06-2023, 09:17 AM
I'll pile on. What you are experiencing is 100% normal.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
