Old 02-07-2023, 11:23 PM #1
Yelxo Yelxo is offline
Yelxo is on a distinguished road
Replacement Engine for 1998 4Runner - reputable company?
Unfortunately I spun a bearing and have been told that I need to replace the engine by my mechanic. I have found a couple of used engines but they have over 300k miles on them - so not inclined to go that path.
I am looking into getting a rebuilt or remanufactured engine and doing research online. Does anyone have any recommendations on a reputable company that they have got an engine from?
And lastly I don't want the added expense of a JDM engine since I won't be wrenching it myself.
A million thanks for any help that you all can provide! I want to keep my truck on the road - the body is mint!
Yelxo is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 12:01 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What engine do you have?
Old 02-10-2023, 02:03 PM #3
bmason8159 bmason8159 is offline
bmason8159 is on a distinguished road
Yota1 performance
bmason8159 is offline   Reply With QuoteReply With Quote
Old 02-10-2023, 03:55 PM #4
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all
JoeT4R's Avatar
Originally Posted by bmason8159 View Post
Yota1 performance
Their current lead time for a 5VZ is 7 to 8 months according to their website. That's a looooong time to wait, but, it's better than not having an engine at all.
Sent from my SM-S908U using Tapatalk
Old 02-10-2023, 04:02 PM #5
ShannanC's Avatar
ShannanC ShannanC is offline
Real Name: Shannan
ShannanC is on a distinguished road
ShannanC's Avatar
Real Name: Shannan
I used JDM King Motors of Houston for my 99. I got a used 5VZFE engine for $1000 roughly and had it installed. 60K on engine with new timing belt, pulleys, and water pump installed from previous owner in Japan. I have around 30K on it now with no problems whatsoever.
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Kinati Mud Hog 315/75R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
ShannanC is offline   Reply With QuoteReply With Quote
Old 02-11-2023, 11:05 AM #6
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
What's the added expense of a JDM engine? Swapping a harness and pulleys? They are generally a better bet. A shop I know has installed plenty of JDM 5VZ and VG33 engines with great luck. You need to inspect the engine before purchasing. Back when I bought mine in 2015, you could find a ton of 5VZs still with NGK plugs in one head and Denso in the other - a fair sign that mileage is quite low.
Sure it's not a 100% verification, but once you deal with an average stateside junkyard that will do anything and everything to make a sale on their junk, then you will see the value in JDM engines. That said, they are WAY more money than they used to be now.
Old 02-11-2023, 12:28 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I don't know of any sources of 'low' mileage US 5VZ-FE engines. Partly because there are not very many low mileage 4Runners, Tacomas and T100's left on the road and even less of those that are wrecked with an intact engine. Try Car-Part.com--Used Auto Parts Market but just know that not all sellers are honest so you have to inspect it and have a compression test done right there. Patience is going to be your best tactic right now. That and your phone dialer - many places won't list inventory until it's on their yard but they can tell you over the phone when they might expect a shipment. Internet searches aren't nearly as good as actually talking to them.
I had a JDM engine installed and it is extra work but they are very good engines. I agree with above that they have become expensive. I paid $1300 for mine 5 years ago but the price is nearly double that now as more and more 5VZ-FE engines are failing and having less junk units worth selling.
326WHP 347TQ
Old 02-11-2023, 04:12 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Another vote for Yota1 Performance. Yota1 has an excellent reputation, but because of that, they have a fairly long lead time and you'll have to shell out a decent amount of money. If you can do the work yourself, maybe roll the dice on a JDM engine. If you are going to pay someone to do the work, definitely go with a rebuilt engine. It would suck to pay for all that labor just to find out you got a shitty engine.
If you want to do the work yourself, I have a 4 part video series you can use.
Part 1:
Part 2:
Part 3:
Part 4:
Old 02-11-2023, 09:39 PM #9
Real Name: Patrick
Real Name: Patrick
Still waiting to hear from the OP if he’s looking for a 5VZ or 3RZ…..
Old 02-12-2023, 01:20 PM #10
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Maybe he found his answer and he doesn't need us anymore. I feel so used and unappreciated.
Old 02-12-2023, 01:29 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is typical . Folks just disappear.
I know I just compression checked and resealed the engine I put in one of my rigs. It had around 170k on it. The only mistake I made was not replacing the injectors as I had one fail 5k or so later. My guess is it was from sitting non running for 3 years. Other than that, the engine is fine.
Old 02-12-2023, 02:50 PM #12
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
with this ? and the same for the trans coming up so many times now, and as more and more 3rd gens r getting to the 300k mark and passed this will keep coming up. It mite b worth making a couple of Sticky's on said subject matter, and people can aslo go into "properly" rebuilding said as in bearings to use, better understanding of head rebuilds, etc etc
tThere r things many of us learn over time that could help others as they go down this path, I know many say JDM engine but they have cons and pluses like any path which could be address at the start of the posting. There is info like, if ur going to rebuild u can use a 3.0L 2nd gen crankshaft which have the same profile as the 3.4L crank but the 3.0L are forged shafts vs the 3.4L cast shafts....
clearock is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 11:22 AM #13
Sorry for the delay responding to these posts - lots of great ideas. My engine is the 3.4L 5VZ.
Old 02-13-2023, 11:24 AM #14
It's from a 1998 4Runner Ltd - so it's the 5VZ
Old 02-13-2023, 02:14 PM #15
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
I went with a jasper about 50K ago, all is good, purrs like a kitten at idle, uses an unmeasurable (on dipstick) amount of oil in 5K OCIs, 15-17 mpg.
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
company , engine , expense , jdm , reputable
Reputable shop in or around Chicago? Power steering rack replacement Sean7 4th Gen T4Rs 4 05-05-2021 02:56 PM
Need Help on JDM 3.4 Engine Swap 1998 4runner Limited Gho5t5niper 3rd gen T4Rs 5 10-22-2013 11:40 PM
Engine Block Warped! True Story! 3rd Gen 4cyl 4runner 1998 bpechtim 3rd gen T4Rs 15 10-02-2011 02:09 PM
Help 1998 4runner 4WD SRS5 standard transmission -engine died willey_coyote 3rd gen T4Rs 14 09-03-2010 06:23 PM
1998 4runner PVC Valve Replacement apwdweb 3rd gen T4Rs 1 10-10-2009 11:41 AM
