Old 02-13-2023, 12:35 AM #1
Boognish_Forever's Avatar
Boognish_Forever Boognish_Forever is offline
Boognish_Forever is on a distinguished road
Change power steering fluid or not?
I'm pretty sure my 99 hasn't had the power steering fluid ever changed. I thought about sucking the old brown fluid out of the reservoir and put new Dexron ATF and keep doing this once a week till its red. Power steering is working fine and have no abnormal noises. The steering rack does have a very small leak and only top it off once a year.
Should I change it out or will this cause more issues with the rack and blow seals with the new fluid. I kind of look at this situation if the transmission fluid hasn't been changed in a very long time and is brown, best thing is to just leave it alone. I also don't want to ruin the pump with old fluid, hence the reason on doing the change. It currently stands at 117,000 miles
Boognish_Forever is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 12:38 AM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I would guess your reservoir filter screen is mostly blocked with deposits. I recommend you follow what I show in this video and give your power steering system some love. You won't hurt anything by doing it.
Old 02-13-2023, 12:45 AM #3
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
I did the above service Tim demonstrates in the video. Although my screen was OK (not good or bad), I was really happy with now having a completely clean screen and new fluid. No issues at all and STILL clean fluid.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 01:03 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
New fluid and remove the reservoir to clean the screen. You’ll be surprised how clogged that screen is. It’s really easy to do and it’s only 3 bolts to remove the power steering reservoir.
Old 02-13-2023, 09:20 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I mostly change the o ring on the bottom of the reservoir when I clean them. So I don't have leaks. Granted, I have 2 of my power steering pumps moaning and they Have clean screens in the reservoirs. :/ milage has to be getting them...
Old 02-13-2023, 09:29 AM #6
I need to do this. However, I regularly suck the fluid out and put new atf in it.
Old 02-13-2023, 09:59 AM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by 19963.4lsr5 View Post
...I regularly suck the fluid out and put new atf in it.
+1 Its all i ever do, turkey baster suck out and refill several times. Here's what the last removal looked like, sun wouldn't even shine thru it, haha.
The power steering works well despite. Luck all.
Change power steering fluid or not?-steering-pump-fluid-jan-20-jpg
Old 02-13-2023, 10:21 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I suck mine out with my brake bleeder hand pump. Does a decent job.
Old 02-13-2023, 04:13 PM #9
I know you deal with rusty runners. Have you ever snapped any bolts when taking off the reservoir?
Old 02-13-2023, 04:15 PM #10
Can you see if the screen is dirty by just sucking out the fluid and not taking off the reservoir?
Old 02-13-2023, 04:27 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Using a bright light or the sun... Yes you can see the screen..:-)
Old 02-13-2023, 10:57 PM #12
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
When I had to clean my reservoir filter due to a whining noise the fluid wasn't changed in around 10+ years so it was overdue. Cleaned the mesh filter but re-used the o-ring and it bit me in the ass. Kept whining despite the many times bleeding it with the wheels up so I figured something was wrong with the pump. Decided to rebuild the pump with new seals (didn't need to do this) and the kit came with an o-ring for the reservoir. Bleeding session #3 using Toyota instructions and it was finally quiet. Pinched o-ring was my issue so I highly recommend replacing it if you remove the reservoir.
I used Tim's video for the PSF flush - worked great! Brand new fluid is great in the system. You don't have to run the truck to flush it out, you can just lift it up on jack stands and turn the wheel lock to lock to manually pump the fluid out.
2000 4Runner Limited 4x4 V6
Old 02-13-2023, 11:00 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Interesting, rebuilding didn't fix it. Thanks for sharing... I always keep o rings in inventory.
change , fluid , power , rack , steering
Whine coming from power steering pump + bubbles in the fluid NOT after fluid change Pyral 3rd gen T4Rs 14 03-19-2022 06:43 PM
Power steering fluid change... Nickdsvt 4th Gen T4Rs 26 03-12-2021 10:41 AM
Power Steering Fluid Change mwebster22 5th gen T4Rs 5 03-17-2017 07:34 AM
Change Power Steering Fluid ALLEGRO General Discussions 3 05-21-2015 11:16 PM
Power Steering Fluid Change ALLEGRO 4th Gen T4Rs 4 05-15-2015 08:08 PM
