Old 02-14-2023, 11:36 AM #1
Madarasskishbosh Madarasskishbosh is offline
Madarasskishbosh is on a distinguished road
Engine turned off after I took of the radiator cap.
Hello,
Need your help asap.
Earlier today I was adding coolant to the radiator since it had been leaking and was hoping to get another today. I might have forgotten that the engine was running, so I took the radiator cap to add more and the engine lost power and turned off. Now the vehicle won’t start. Is there something I should do? Could I have damaged something in this process? I’ve been looking online and haven’t come across anything.
Thanks in advance.
Quick update:
Located the fuel pump under the seat and hit on it with a flashlight. It started!
Looks like it was just clogged.
I’m going to need to replace it soon.
How long do y’all reckon I could drive it around until it fails completely?
Madarasskishbosh is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 11:50 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Madarasskishbosh View Post
Hello,
Thanks in advance.
You dump antifreeze in your oil and seize the engine? Or you seize the engine by running it past H?
As that's the only way I see an engine seizing from what you are explaining .
Old 02-14-2023, 11:57 AM #3
I was just adding coolant to the radiator. Put the radiator cap on and took it off again hoping to put some more. As soon as I took it off the engine lost power and the vehicle turned off. Honestly, I do not know what I was thinking opening the radiator while it was running.
Old 02-14-2023, 12:01 PM #4
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I'm a bit curious about this scenario, it's not like the engine isn't inches away, and the fan is spinning, and it's making a lot of noise. How could you forget? Ah well, you did it, either way.
It's very unlikely that the two things are related. The engine will happily run with no pressure in the cooling system, the ECU doesn't even know what the pressure is, only the temp. And it won't shut the engine off if it's too high (or low, or the sensor if shorted or open circuit). It might alter the mixture enrichment some based on what the sensor says the engine is doing.
Did coolant spray out and back onto the running engine in any significant amount? It's faintly possible that could have shorted something out. But generally, the engine can run with water getting doused on it (like when you're driving in the rain).
Was it really low on coolant before this and eventually overheated and was in the process of seizing up when you took the cap off? Did it just happen to run out of gas at the same time?
But no, there's probably no direct connection between you taking the cap off and the engine dying. You'd need to start troubleshooting with the basics. Air, spark, fuel.
JohnMc is offline   Reply With QuoteReply With Quote
Old 02-14-2023, 12:07 PM #5
It could have ingested the coolant he just poured in and stalled.
Pull some spark plugs
Check for spark
See if any plugs are wet with coolant or smell of gas.
Old 02-14-2023, 12:10 PM #6
I guess it depends on where they actually poured the coolant. Or a severely blown HG?
Old 02-14-2023, 12:27 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Will the engine spin? Like the starter can spin the engine. Or does it just go thump....will the engine crankshaft turn is basically what I am asking?
Old 02-14-2023, 01:04 PM #8
It does attempt to start. You could say it starts (faintly) but then immediately shuts off again.
Old 02-14-2023, 01:05 PM #9
Thank you. Will have it looked at by a mechanic.
Old 02-14-2023, 01:08 PM #10
No, coolant did not spray on the engine.
It was a cold start, had been running for a few minutes only and still had coolant in the system (not significantly low). Gas is at half tank.
Old 02-14-2023, 05:23 PM #11
nissanh nissanh is offline
Do you have fuel in the tank? Clogged fuel filter?
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 02-14-2023, 05:34 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh good. Then it's something minor. It's not seized or anything. Just not firing. Very possible the radiator cap had nothing to do with it and you just have something minor wrong.
Old 02-14-2023, 11:01 PM #13
Turns out this was it. Hit on the pump and it started right up.
Old 02-15-2023, 12:07 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Your vehicle had no gas in it and that's why it wouldn't run. Gee that's a simple fix not related to the coolant issue at all. Does your gas gauge not work?
Old 02-15-2023, 11:10 AM #15
The pump is inside the tank, what did you hit?
cap , engine , radiator , today , turned
Sudden brake turned the check engine light on ad_robotics 4th Gen T4Rs 7 11-21-2023 11:16 AM
Check engine light turned off by itself... what to do? CelticRunner General Discussions 11 06-21-2019 10:07 PM
small puff of steam when I turned the engine off thegipper 3rd gen T4Rs 19 07-23-2017 09:24 PM
varnish or bad fuel smell when engine is turned off hawaiianv New Members 0 07-11-2013 06:49 AM
everything resets when engine turned off rwhoke Problems & Warranty Issues 2 07-05-2008 06:56 AM
