02-15-2023, 11:35 AM
Official Vendor
Official Vendor
Toyota Scan Tool (ABS bleed and SRS codes)?
Hey, anyone have any recommendations for a scan tool to read the airbag codes and perform ABS bleeds?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
02-15-2023, 02:27 PM
Real Name: Patrick
Real Name: Patrick
You aren’t going to find any aftermarket tool capable of that. The abs/airbag modules don’t communicate with any other module or through the Obd2 connector in the cab.
Edit: Toyota has an SST for abs pump activation
02-15-2023, 02:44 PM
And the rest of us use a gravel/dirt road...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-15-2023, 03:04 PM
Can I ask what an SST is?
Specialty Service Tool?
02-15-2023, 10:14 PM
Real Name: Patrick
Real Name: Patrick
Special Service Tool. It’s “Toyota” for a tool required to service a part or component. All auto manufacturers have a version of this. Could be anything from an airbag diagnostic tool to a piston installer to a seal installer etc.
02-16-2023, 02:17 AM
Check autoenginuity maybe. They do a ton of actuation stuff. I should be able to fire up mine sometime tomorrow evening and see if it does Toyota ABS. I know it did my 05' Ram.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
02-16-2023, 05:14 AM
What in the world would it be for on our abs though? I don’t even think you can communicate with it. Just use the shorting bar. Unless one of those positions runs the abs motor which I’ve been searching for off and on for years……
02-16-2023, 11:48 AM
Official Vendor
Official Vendor
What's the shorting bar?
keith
eimkeith.com
02-16-2023, 11:50 AM
Official Vendor
Official Vendor
Any idea of the part number for that SST? (I might have to dig out my manual)
not opposed to buying a factory tool
keith
eimkeith.com
02-16-2023, 12:04 PM
Real Name: Patrick
Real Name: Patrick
I think the SST from Toyota can activate the pump and valves as needed, but it's probably been obsolete for so long I'm willing to bet most dealers don't even have it anymore. I think it actually plugs up to the abs motor to control it.
02-16-2023, 12:06 PM
Real Name: Patrick
Real Name: Patrick
I don't have a clue, and my 2000 FSM isn't working to see if it's listed or referenced anywhere.
02-16-2023, 12:28 PM
Official Vendor
Official Vendor
ok, found it - SST 09990-00150 for the ABS ACTUATOR (now just need to find one) EDIT - part number superseded to 09990-00141
also, the SRS code check is on DI-364 through DI-366 of my '96 Manual (paperclip method)
keith
eimkeith.com
02-16-2023, 03:56 PM
To bleed the ABS, drive on a dirt road/gravel road and brake to lockup the wheels (CHECK BEHIND YOU before you step on the brakes), Do multiple rounds and then bleed at the wheels. I did this to my 2000 landcruiser and it worked. Many advice to use a scan tool to bleed the brakes in this manner, but dirt road method works too!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
02-16-2023, 04:56 PM
Official Vendor
Official Vendor
Unfortunately, I need to be able to diagnose & bleed in the shop environment - because of my location.
keith
eimkeith.com
