Old 02-16-2023, 03:27 PM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Window seal replacement
Does anyone know of after market replacements for the window seals (part #68162-35010) for a 3rd gen? The OEM’s seem a bit overpriced and I’m trying to find an alternative. If I can’t find a decent priced replacement, I’m just gonna see if I can grab some from pick and pull.
Thanks
stevew092984 is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 03:42 PM #2
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Pick n pull is a good option. If the seal is just leaking, you may want to try your luck with some silicone before replacing the whole seal. I used some Permatex recently for this and it worked great.
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 04:14 PM #3
Maybe seal is the wrong word. It’s the rubber that rubs against the drivers window as it’s being rolled down. The rubber will fold in on itself making me think the felt on the inside has worn out. Hope that better describes the part I’m talking about.
Old 02-16-2023, 05:34 PM #4
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Thanks
Outer Window Weatherstrip Belt Molding is what you're looking for.
Older the model the less supply & demand i.e. higher price w. less aftermarket availability.
68161-35010 Weatherstrip FR
68162-35010 " " FL
68163-35010 Weatherstrip RR
68164-35010 " " RL
68290-35020 Weatherstrip Assy (rear gate)
Front: OEM TOYOTA 4RUNNER EXTERIOR WEATHERSTRIP SET FRONT 2 WINDOWS ONLY 1996-2002 | eBay
Rear: OEM TOYOTA 4RUNNER EXTERIOR WEATHERSTRIP SET BACK 2 WINDOWS ONLY 1996-2002 | eBay
Window seal replacement-s-l500-jpg
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 06:06 PM #5
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
That's called a Belt Molding.
Toyota 4Runner 96-02 Door Belt Molding Kit Set Weather Strip (4 pc.) Genuine OEM | eBay
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 06:16 PM #6
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
If I'm not mistaken, I believe @Bad Luck recently replaced his. He may be a good source to have chime in on this topic.
Sent from my SM-S908U using Tapatalk
Old 02-16-2023, 06:33 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It wasn't me. I'm not sure who it was either. Hmmmmm
Old 02-16-2023, 07:05 PM #8
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
I did mine not that long ago. Yeah they are pricey online, approx $50 per door. I did the rear hatch one as well and that requires taking the panel off.
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 07:09 PM #9
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Just go get one at the junkyard, these things don’t really wear out that often and are always pretty expensive new. I put a product called gummi pflege stift on the weather stripping on all my cars and it seems to really rejuvenate it and keep it in nice shape
RandyBobandy is offline   Reply With QuoteReply With Quote
find , i’m , replacement , replacements , window
Replacement Wheel Bearing - HUB Seal/Dust Seal? joesrcool 5th gen T4Rs 11 06-22-2022 12:40 AM
07 4Runner Outer Window Seal Replacement Questions Axe_78th 4th Gen T4Rs 13 12-14-2016 01:08 PM
Inner seal/ axle seal replacement razzman1 4th Gen T4Rs 4 08-27-2015 07:07 PM
'07 4Runner outer Window Seal Replacement Question Axe_78th Maintenance/Detailing 0 08-04-2014 05:04 PM
Rear window seal replacement Calimander 4th Gen T4Rs 4 12-07-2013 11:56 AM
