Old 02-17-2023, 08:24 PM #1
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Fuel tank strap rusted through
Tin worm never sleeps.
During winter road trip rear seated passengers complaining about a loud thumping sound when driving over just about any moderate bumps/road irregularities.
Pulled over, took a quick look underneath, nothing obvious. Figured maybe rear shock upper mount, exhaust/muffler or something else came loose.
Fast forward couple weeks did a more thorough inspection while up in the air on lift.
Gas tank strap rusted through, tank basically bouncing around on top of fuel tank skid plate.
Picked up rust free used OEM strap.
Install was no fun, snapped one of the skid plate bolts as well as bolt securing fuel tank strap. This was after 2 weeks of daily applications of Kroil to all hardware.
Heat would have prevented busted bolts but so close to the fuel tank is a no no, at least for me.
Moral of the story…….check your fuel tank strap if your rig has spent time in an area of the country where the winter roads are salted.
All buttoned up and ready for another 200K miles.
Fuel tank strap rusted through-b0183ad1-9a9a-49ed-aa72-9421599f48f5-jpg  Fuel tank strap rusted through-d5d5e0f8-fa55-45bb-8c8e-391f10047ae5-jpg  Fuel tank strap rusted through-803cf75d-8359-4f6a-93c7-08843d7b8eb1-jpg
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 02-17-2023, 08:37 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Been there done that. That's how i fixed one of mine. Good to see you sourced a good oem used one. :-)
How is the crossover tube holding up?
The rest of the brackets and nuts good?
The tank good?
brillo_76 is online now   Reply With QuoteReply With Quote
Old 02-17-2023, 09:08 PM #3
The tank good?
Fortunately no issues with crossover tube, remaining brackets/hardware or fuel tank……all solid with no perforation.
Routinely apply Fluid Film to most of the undercarriage, especially hardware and key areas prone to rust.
As you know, a never ending battle!
2002 SR5 Sport 4WD
Old 02-18-2023, 10:51 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes sir. I definitely know. It's you against the environment. steel isn't happy in the rust belt.
Old 02-19-2023, 08:46 AM #5
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
So if I press on my fuel tank should I be able to hear a rattling sound if my strap is bad? I'm having some rear end noise after replacing my rear shocks and everything is tightened down properly. I just can't tell if it's the rear shocks themselves or purely coincidence. Didn't touch anything during the replacement process.
Sent from my SM-S908U using Tapatalk
Old 02-19-2023, 08:59 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
These are known to rust off. Mine was held in by the skid plate.
If you press on your fuel tank it should not move or make any noises.
Old 02-19-2023, 10:10 AM #7
My strap had rusted in half completely. You really couldn’t tell just by looking at it.
Like Jon described above, my tank was also resting on the skid plate after the strap broke.
I got underneath the truck and pushed up on the gas tank and could easily lift it. Did this when the tank was less than 1/4 full so not to heavy.
If the strap is intact and supporting the tank it should not move at all as the strap keeps it tightly in place.
Hope this is helpful.
2002 SR5 Sport 4WD
Old 02-19-2023, 11:07 AM #8
JoeT4R's Avatar
JoeT4R's Avatar
I'll definitely give this a shot when I go out to my truck. If I step on the rear bumper I can bounce the truck and I hear something that sounds loose, like metal clanking on metal. I cant imagine it's coincidental but just definitely think it's worth looking into for sure. Thank you for the info.
Sent from my SM-T220 using Tapatalk
Old 02-19-2023, 12:30 PM #9
I have a feeling this may not be your problem but definitely worth checking out as having the tank bounce around is never a good thing.
Not a bad job if needed though rusted hardware always a concern when in living in an area where the roads are treated in the winter.
2002 SR5 Sport 4WD
Old 02-19-2023, 04:12 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You know, I been slowly switching out the hardware for stainless nuts and bolts. Especially the small diameter and exhaust bolts. I am betting in time, this will make things easier...
bolts , fuel , strap , tank , weeks
3rd gen fuel tank strap length franky73 3rd gen T4Rs 4 06-22-2022 07:44 AM
Fuel Tank Strap Replacement. Maineiac 4th Gen T4Rs 6 04-22-2021 05:41 PM
Fuel tank strap replacement Porqupine82 4th Gen T4Rs 0 10-18-2016 09:44 PM
Fuel tank support strap chimpy 3rd gen T4Rs 4 06-22-2015 09:53 AM
Rusted Fuel Tank Shield banq010 3rd gen T4Rs 0 11-16-2014 07:56 PM
