Old 02-28-2023, 10:26 PM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by revans611 View Post
Update: 8 days later and still no problem with the battery light. The alternator replacement must have fixed it.
Great news. Let us know how long the aftermarket alt lasts. As I think they use cheaper soft brushes which last as long as the densos do .
Time will tell how long it will hold out. Maybe your luck is better then most.
Old 03-01-2023, 01:12 AM #17
revans611 revans611 is offline
revans611 is on a distinguished road
Originally Posted by JoeT4R View Post
Glad to hear you're having good results so far. Be careful with the stuff you get from auto parts stores, especially when it comes to alternators/starters. They tend to wear out a lot quicker than your Denso/OEM stuff. I had an aftermarket parts store alternator quit on me after only 4 years. Bearings went bad.
I think you are probably right about OEM vs auto store parts. I once had a horrible experience with a non-OEM clutch pressure plate. It "shuddered" when starting off in 1st gear. Took it back to the mechanic who installed another non-OEM part with the same result.
Then I phoned in to a local radio station car repair show. The very experienced host suggested that I go OEM. I did, and the problem was solved.
revans611 is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 07:54 AM #18
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
There's a few things that I'm okay with not using OEM parts for, but for the most part I try to stick with Toyota stuff. It just all depends.
Old 03-01-2023, 09:15 AM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I can confirm he is correct. Don't get me wrong, it's an extreme shame. However, there isn't a comparison between the 2. It's just reality.
There are parts you can get away with, though. Like brake pads, suspension, and Tires as examples.
Major Drivetrain parts it's best to use oem mfg in place of oem if need be.
alternator , battery , check , light , mechanic
Battery > alternator check out Traveler74 3rd gen T4Rs 6 08-07-2020 01:29 PM
Battery light still on after replacing alternator Eugene13 Classic T4Rs 5 06-13-2019 02:55 PM
Can you check what voltage your alternator is putting to the battery? chayos00 4th Gen T4Rs 9 04-11-2014 07:09 PM
Replaced Alternator but battery light is still on. GypsyRose 3rd gen T4Rs 4 09-20-2013 12:49 AM
Battery light keeps flashing!!! trail_runner 3rd gen T4Rs 7 12-01-2011 12:20 AM
