Old 02-23-2023, 04:40 PM #16
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
To hijack a little bit I've been thinking about getting one that fits specific criteria.
-not crazy expensive but still quality
-9"-10" screen that can extend up above the Dins as much as possible
-Want that extension for navigation specifically for offroading but also on. Our dins are so far down it would not be safe to look down for navigation. So obviously this means android hookup would be nice, it will piggyback off my phone so I don't need full standalone.
-I don't need top notch audio quality, not a huge audiophile and very often not even listening to music
-physical volume knob would be nice and/or maybe a remote that I can strap to my wheel.
-At least 2 video inputs, more would be better if I decide to get super fancy with undercarriage cameras. Split screen function would be great too, perhaps I might even go with one of those vid combiners though too.
That's my main criteria. I spent a ton of time on amazon recently and couldn't find anything that fit those that didn't seem a little suss judging by reviews.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 02-23-2023, 05:39 PM #17
JohnLocker's Avatar
JohnLocker JohnLocker is offline
JohnLocker is on a distinguished road
JohnLocker's Avatar
Originally Posted by Zhehan View Post
That seems cool. I have a DUAL subwoofer in my 4Runner and it slams. I also used to have DUAL turntables back in the day. Good brand.
I was a bit skeptical on it at first cause it looks to good to be true
JohnLocker is offline   Reply With QuoteReply With Quote
Old 02-23-2023, 05:56 PM #18
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
This is what I'm rockin' in my 2005 4th Gen Sport: I went all out building this for performance and an incredible sound stage that'll have your ears ringing.
--> Alpine-iLX-W650 receiver and KTA-450 amplifier (50 watts RMS x 4 at 2 or 4 ohms) ~$584.89 pkg.
Alpine iLX-W650 and 4-channel Amp Package Includes iLX-W650 multimedia receiver, dockable KTA-450 amplifier, and amp wiring kit at Crutchfield
For my 2011 5th Gen SR5 I went 'budget' instead of performance: A really nice head unit for the money.
--> Boss BV800ACP receiver ~$249.99
Boss BV800ACP Digital multimedia receiver (does not play CDs) at Crutchfield
Both of these are double-din, touchscreen w/ CarPlay for both iPhone and Android.
Issues w/ the Alpine: CarPlay USB cable connects to the back of the unit "inverted" which is a pain in the !@#$. I anchored it w/ a zip tie to the antenna input connection to keep it from moving. Even still, the USB cable can be flakey as hell and the unit will show "Device Unsupported" if the connection is weak. To remedy this use a good solidly made Lightning cable. I recommend getting an Anker cable: https://www.amazon.com/stores/page/9...-50C640189C14/
Also: Alpine does not support their flagship top selling HU, the iLX-W650 on their Tuneit app. ??? Come to think of it... not much support, period!
Issues w/ the BOSS: If you are connected to CarPlay and have an iPhone 12 Pro Max you can consistently expect to hear voice echo. There are a few ways to remedy or work-around since Apple won't own up to it being the phone at fault. Again, I recommend an Anker cable. Regardless of what the manual says, install the mic on the steering wheel column right behind the steering wheel for optimum call quality. Also turn down the CarPlay gain a few notches from its default setting or until you find the sweet spot.
Also: When connected to CarPlay your B-Tooth is disconnected. When using B-Tooth for calling instead of CarPlay you will NOT have a voice echo.
BOSS also has a built-in internal amp (20 watts RMS/80 peak x 4 channels)
I agree with an earlier Reply in that Kenwood is always a good choice as it was my goto back in the 80's and 90's.
Note: If you order from Crutchfield they will give you vehicle specific accessory options i.e. metra harness, and installation gear, steering wheel module, etc. And usually throw some of it in for free. You also receive personalized installation instructions to go along with you order. Lifetime technical support and superb customer service and "no hassle" return policy.
Units w/ touchscreens 9" and above be prepared to pay more than what I paid for both. The cheapest one I found was $349 and they go well over $1,000+ depending on the model.
I am very happy with both of the head units in my 4runners.
Hope this helps, and good luck!
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 02-23-2023, 08:33 PM #19
JohnLocker's Avatar
JohnLocker's Avatar
The one I linked is not from Crutch this is my first time doing this
cockpit , iphone , note , spice , stereo
Stereo Replacement with knobs - NO TOUCHSCREEN meltdowner 4th Gen T4Rs 6 08-27-2019 02:15 PM
SOLD: Toyota/Scion FR-S Touchscreen Radio (T10071) Touchscreen radio- $175 rmstucky For Sale: T4R Items 0 11-28-2018 11:37 AM
What stereo and alarm systems do you use? Atrox Caeda 3rd gen T4Rs 11 08-01-2012 05:04 PM
First generations with aftermarket stereo systems Charlie_Hustle Classic T4Rs 4 12-18-2010 09:59 PM
