Old 02-24-2023, 02:43 PM #1
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Possible brake booster issue?
So this has happened 3 times now in very cold conditions (single digits but not everytime). Basically I just start the truck up and the first time I really hit the brakes while moving they are hard as a rock and I have to pump them 2-3 times and they soften up and actually brake the vehicle. Is this an indication of the booster going bad? Perhaps there is condensation on a valve in there that sometimes freeze up said valve? Other than that initial thing it's working totally fine (other than maybe just needing a good solid bleed in general).
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 02-24-2023, 02:49 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mine will do that from time to time when it's really cold. I don't think anything of it.. ( That might be good or bad)
Old 02-24-2023, 02:53 PM #3
Well I think we can rule out rust issues on our problem since I don't have those lol. Yeah it's not been an issue after that initial hard pedal. I probably just need to be mindful on cold days to check the pedal at slow roll until I pull out into the road. First two times it happened was 1/4 mile down the road. Always a little terrifying when you are pulling up to a light and it happens, one time I was behind a school bus. Glad I drive like a grandma for the most part in this truck. Last time it was while I was backing up from my parking spot in the road to get around my roommate. I think possibly first two times I didn't have to back out of my spot. I'll keep an eye on things to see if I can figure this out more but I know I always put my foot on the brake initially to disengage the parking brake and get into gear and I don't have the problem then. Super weird.
'98 SR5 5 Speed
Old 02-24-2023, 03:12 PM #4
spartacus's Avatar
spartacus's Avatar
A couple of minutes of warm up could help. The check valve might be gummed up.
Old 02-24-2023, 03:28 PM #5
Yeah I don't think it's ever happened after a good warmup, only when I don't do that. Makes sense that some condensation could be working it's way up from the intake into that vacuum line and freezing the check valve up until I give it enough pedal to unstick it. I guess not really anything that can be done about that which I guess is good and bad. At least it indicates I don't have to buy anything/work on it.
'98 SR5 5 Speed
Old 02-24-2023, 07:01 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
First time it happened. I thought my brakes were frozen and it scared the heck of out me as the brakes didn't work for a few seconds..lol
Old 02-25-2023, 05:09 AM #7
I’d think about replacing the check valve. It’s done it to me on two separate rigs.
Old 02-25-2023, 12:03 PM #8
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Sounds like the check valve.
Had the same problem on my 2nd gen and replacing the check valve solved the problem.
Had the problem on my 3rd gen and I sprayed the check valve with silicone lube and that fixed it.
In my case warming it up didn't help at -30.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 02-25-2023, 05:12 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I will need to investigate that check valve.
Old 02-25-2023, 09:41 PM #10
Did you remove the valve and spray into it?
'98 SR5 5 Speed
Old 02-26-2023, 12:45 PM #11
I didn't remove the valve but I removed a hose on one end of the valve and sprayed into it. It's been good for 5 winters since.
I actually used Tri-Flow lube.
booster , brake , thing , times , valve
Brake Booster?? 94KC4runner Classic T4Rs 10 03-19-2023 01:05 PM
ABS Booster Pump Issue tpete 5th gen T4Rs 7 12-13-2022 10:18 AM
WTB - 99 2wd Brake Booster ICD For Sale: T4R Items 0 08-30-2021 12:15 AM
anyone ever mess up a brake booster by changing brake pads? jluu6r 3rd gen T4Rs 19 12-12-2019 05:01 PM
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 23 11-01-2019 04:15 PM
