Old 02-24-2023, 09:07 PM #1
Madarasskishbosh Madarasskishbosh is offline
Madarasskishbosh is on a distinguished road
Brake Buzzer
Hello once more,
I recently replaced the Skid Control ECU (Part No. 89540-35270). Before this both the odometer and speedometer weren’t working at all. CEL, Brake, VSC OFF, VSC TRAC and ABS light were all on along with a constant brake buzzer coming from the ABS Control Module/Booster. After replacing the ECU the VSC OFF and VSC TRAC light remained on and all other lights went off. The speedo and odo function properly. I performed a zero point calibration and got rid of both lights. The only thing that remains is the brake buzzer. Is there any other way I could get rid of this or does this indicate another malfunction? I’ve researched online, but haven’t found anything really helpful.
TIA.
2001 Limited 4WD.
Madarasskishbosh is offline   Reply With QuoteReply With Quote
Old 02-25-2023, 08:32 AM #2
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
This brake buzz you speak of... Is it the abs module just doing it's thing? "Priming" I think it's referred to as? Or is this a constant noise that doesn't stop the entire time you're driving? Interested to know a little bit more.
Sent from my SM-S908U using Tapatalk
Old 02-25-2023, 11:12 AM #3
It happens often. I’d say every five to twenty minutes. Most of the time when I step on the brake. Also happens upon startup.
I doubt it’s a normal thing, or it could be. This is my first time owning a 3rd gen so it could be a normal thing and I’m just not familiar.
It’s an actual buzzer coming from the ABS Module.
Sounds something like this: Buzzer sound effect - YouTube
It buzzes for about 10 seconds, sometimes not so much.
Old 02-25-2023, 12:14 PM #4
JoeT4R's Avatar
JoeT4R's Avatar
...did I just get trolled?
If that's really what it sounds like then I have absolutely no clue whatsoever. Hopefully someone else will chime in with better information for you.
Old 02-28-2023, 12:47 PM #5
that3rdgen that3rdgen is offline
that3rdgen is on a distinguished road
Do you have an aftermarket alarm system? as mine buzzes like that when i open the door with the key rather then the remote.
1996 SR5 4Runner "Felipe"
@felipe_t4r on insta
that3rdgen is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 10:34 AM #6
I don’t think so. My alarm goes off when I open with the key as well but it isn’t a buzzing sound rather than consecutive honks until the key is in the ignition
Old 03-02-2023, 04:38 PM #7
nissanh nissanh is offline
Did you bleed the front brakes? If not, drive on a dirt road and lockup the wheels to activate the ABS unit.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
brake , buzzer , control , ecu , vsc
Ignition buzzer mikesmith140 Classic T4Rs 7 09-04-2014 07:09 PM
“Parking Brake On Warning Chime Or Buzzer” jow 4th Gen T4Rs 17 09-28-2012 10:04 AM
Headlight Buzzer? LexKing Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-01-2010 11:10 PM
E Brake Warning Buzzer AE1M 4th Gen T4Rs 11 11-09-2009 06:58 PM
Buzzer 90whiteRunner Classic T4Rs 10 04-16-2008 06:17 AM
