Old 02-28-2023, 01:25 PM #31
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
Not to the letter. The brake tubes where connected after replace the MC piston kit. Then the tubes where loosened one at a time while the brake pedal was pumped.
Originally Posted by phattyduck View Post
What was your master cylinder bleed procedure? Did you follow the FSM to the letter?
It is NOT the normal procedure for bench bleeding a master cylinder, which is why I ask. Also note the bleeding order for the wheels.
You likely have two things stacking up - incorrectly bled master AND air bubbles in the ABS system. Once you get the master cylinder bled correctly (you'll hear a little "clink" in there when doing it - that's the thing on the side that helps with brake feel on the rear drums). Then you'll have enough pressure to go for a drive and activate ABS on a low-traction surface - then re-bleed, and repeat.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 02-28-2023, 01:39 PM #32
If you left the brake line tube fittings loose when you released the brake pedal you just put air back in the MC.
Old 02-28-2023, 04:45 PM #33
That is definitely (at least part of) the problem. Open while pressing, sealed while releasing is required once the normal "pump a bunch" part of a bench bleed is done.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-01-2023, 03:35 AM #34
problem solved.
we followed this except no speed bleeders were used. also re-bled the MC as per @phattyduck 's post
haven't bled the ABS actuator though. will have to look for a low traction surface long enough to allow me to play.
Thank you very much guys!! your help is very much appreciated!
Originally Posted by 19963.4lsr5 View Post
Don’t pump the brakes before opening bleeder.
Let it sit overnight and then do another gravity bleed on all 4 corners until no air bubbles are in the clear hose.
Then bleeded with the pedal by doing this until no air bubbles are seen:
Open bleeder-push pedal to the floor-close bleeder-release pedal.
I don’t like speed bleeders…..and if you don’t have a friend that can listen to instructions them buy the Motive Pro pressure bleeder.
When you pump the brakes to make pressure you make a million air bubbles that end up everywhere
Black fluid means it’s absorbing moisture.
I use the synthetic dot 3/4
when I say “no air bubbles seen” I mean after a long while.
Old 03-01-2023, 03:37 AM #35
during re-bleeding, the tube fittings were loosened while the brake pedal was pressed.
Old 03-02-2023, 04:41 PM #36
nissanh nissanh is offline
Drive on Sand and lockup the wheels to activate the ABS! Are you in Qatar? I am traveling via Qatar soon!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
brake , brakes , lines , pedal , problem
Having the long brake pedal travel/low brake pedal mystery problem Dragon_EX 3rd gen T4Rs 16 05-19-2021 10:58 AM
Brake problem *need help* 98piranha 3rd gen T4Rs 4 07-21-2017 05:44 PM
Brake problem and Lock problem Fldivemaster16 4th Gen T4Rs 3 05-15-2013 03:45 PM
Brake problem and Lock problem Fldivemaster16 3rd gen T4Rs 1 05-14-2013 02:09 PM
brake problem please help strobed04runner 4th Gen T4Rs 1 10-04-2009 12:49 AM
