02-26-2023, 01:19 PM
When to replace lower ball joints?
Hi. I'm trying to find out how many miles should the lower ball joints last? I have a 3" lift and do some light/moderate offloading. At what mileage interval should they be replaced?
I'm finding threads that talk about replacing them with over 200k miles for peace of mind. But I want to know when after they are replaced should you replace them again?
Thanks
2000 4runner limited
02-26-2023, 01:40 PM
Manual says 100k I believe but personally I do them at 80k
02-26-2023, 01:46 PM
It's not so much a question of milage interval, to many variables affect that. It's more when they show the first signs of wear. My suggestion is to jack up your control arms one at a time and put a pry bar between the LCA and spindle and see if there is any slop when you pry down. So this every oil change or some other frequent interval. Replace the moment you sell any slop. Also if you ever have to pop those ball joints off for other jobs (CVs, suspension, etc) that's a good time to feel how tight the ball is in the cup which should give and even finer approximation of the ball joint health.
'98 SR5 5 Speed
02-26-2023, 04:15 PM
Real Name: Jon
Real Name: Jon
The lower ball joints topic has been thoroughly discussed on this forum for years.
google search:
site:toyota-4Runner.org/3rd-gen-t4rs/ when to change lower ball joints
[using the sticky for alternatives searching and you can spend hours on that topic. :-) ]
Notes: Use the bolts that spiker engineering tested and proved that are the best.
keep with normal size tires and rim sizes and if not off roading 100k is a good estimate or replacement interval.
You can also use tim the toolman videos to measure the ply.. As you can not feel the (.5mm max amount of ply in the joint (I think that's the number))
02-26-2023, 07:39 PM
If you're going to replace them, I'd recommend the Sankei 555 brand. Made in Japan, they are the OEM supplier and the version they sell is greaseable. Here's a link:
SANKEI 555 Front Lower Ball Joints Made in JP 2 Pieces For Toyota 4Runner 96-02 | eBay
I have these and bought from that seller. They also sell the 555 Inner and Outer Tie Rods.
My .02
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
02-26-2023, 08:25 PM
Originally Posted by Zhehan
I like 555 parts! Good advice!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
02-27-2023, 12:43 AM
Real Name: Keith
Real Name: Keith
FYI: Forum consensus, developed over many years and many reports from members, is to strongly prefer only OEM Toyota lower ball joints. 555 Sankei have been reported---anecdotally, of course--- as failing early.
Look at it this way: The Toyota OEM design is weak, engineering-wise. Why go down market from there?
02-27-2023, 01:36 AM
Noted. The pair I bought came in Sankei 555 branded packaging, made in Japan. I was under the impression that Sankei is an OEM manufacturer for Toyota. These units seem super-high quality to me. The casting of the arm in which the LBJs are mounted looked far better than anything I saw at the typical parts houses. Is it possible that the complaints of poor quality are from folks who got counterfeit goods?
02-27-2023, 08:04 AM
Thanks for this input. You learn something every day!
02-27-2023, 09:01 AM
The overwhelming consensus on this forum (and it's been that way for many years) is to only use OEM LBJ's and replace the bolts. I highly recommend you take that advise.
As to your original question, I believe most guys say every 100k miles. If you wheel a decent amount, you may want to replace sooner.
Good luck
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
02-27-2023, 09:55 AM
I agree with the above and
@ pluton
, with as something as crucial and important like LBJ's, I'd definitely go OEM and nothing but. Things like, timing belt, water pump, VCG's and a few others to name a few. You can't risk something like that with aftermarket parts.
02-27-2023, 09:57 AM
Real Name: Mark
Real Name: Mark
When needed YMMV.
You can do the by the book inspection if you have the tools, .5mm(.020") wear limit hard to see with naked eye.
For a rough check I do the prybar check when doing tire rotation, if you can see movement with naked eye
your in the Oh Chit stage. What brand you use up to you, I go Toyota.
02-27-2023, 05:39 PM
555 stuff is generally very good, and they are an OEM supplier for Toyota - maybe even for the 3rd gen lower ball joints. The problem is, the aftermarket parts are not the same design as the OEM ball joints, which is the problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-27-2023, 05:56 PM
Copy that. I thought having a greaseable joint would be better. I made this decision before joining this forum. This forum did not come up in any of my searches at the time when researching LBJ's. I found out about the 2001-02 recall and felt like avoiding an OEM joint due to that issue...
But, thanks everyone for all the input.
Cheers.
02-27-2023, 07:31 PM
The one time I dropped my guard I got burnt.
Have always gone with factory Toyota OEM replacement parts when replacing a critical part or a part that involves a lot of labor to replace.
LBJ replacement…….OEM from reputable online Toyota dealer parts dept.
Same thing when I replaced rear wheel bearings, retainers & seals as well as valve covers and related parts.
Couldn’t resist the lower price advertised on eBay for supposedly factory OEM parts when time came to replace the inner tie rods.
They arrived couple weeks after purchase but I didn’t attempt to install for almost a year later.
Once I removed the original OEM parts I quickly realized the replacement parts were counterfeit parts and not OEM as advertised.
Purchased another pair from reputable Toyota dealer, lesson learned.
Still have the counterfeit parts on my workbench to remind myself never to make the same mistake 2X!
When it comes to LBJ’s, go OEM directly from the dealer.
2002 SR5 Sport 4WD
