Old 02-26-2023, 01:19 PM #1
4runnerfever67 4runnerfever67 is offline
4runnerfever67 is on a distinguished road
When to replace lower ball joints?
Hi. I'm trying to find out how many miles should the lower ball joints last? I have a 3" lift and do some light/moderate offloading. At what mileage interval should they be replaced?
I'm finding threads that talk about replacing them with over 200k miles for peace of mind. But I want to know when after they are replaced should you replace them again?
Thanks
2000 4runner limited
4runnerfever67 is offline   Reply With QuoteReply With Quote
Old 02-26-2023, 01:40 PM #2
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Manual says 100k I believe but personally I do them at 80k
Old 02-26-2023, 01:46 PM #3
Rushthezeppelin Rushthezeppelin is online now
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
It's not so much a question of milage interval, to many variables affect that. It's more when they show the first signs of wear. My suggestion is to jack up your control arms one at a time and put a pry bar between the LCA and spindle and see if there is any slop when you pry down. So this every oil change or some other frequent interval. Replace the moment you sell any slop. Also if you ever have to pop those ball joints off for other jobs (CVs, suspension, etc) that's a good time to feel how tight the ball is in the cup which should give and even finer approximation of the ball joint health.
'98 SR5 5 Speed
Rushthezeppelin is online now   Reply With QuoteReply With Quote
Old 02-26-2023, 04:15 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
The lower ball joints topic has been thoroughly discussed on this forum for years.
google search:
site:toyota-4Runner.org/3rd-gen-t4rs/ when to change lower ball joints
[using the sticky for alternatives searching and you can spend hours on that topic. :-) ]
Notes: Use the bolts that spiker engineering tested and proved that are the best.
keep with normal size tires and rim sizes and if not off roading 100k is a good estimate or replacement interval.
You can also use tim the toolman videos to measure the ply.. As you can not feel the (.5mm max amount of ply in the joint (I think that's the number))
Old 02-26-2023, 07:39 PM #5
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
If you're going to replace them, I'd recommend the Sankei 555 brand. Made in Japan, they are the OEM supplier and the version they sell is greaseable. Here's a link:
SANKEI 555 Front Lower Ball Joints Made in JP 2 Pieces For Toyota 4Runner 96-02 | eBay
I have these and bought from that seller. They also sell the 555 Inner and Outer Tie Rods.
My .02
2000 4Runner SR5 Manual Trans Federal Emissions - Tundra TRD/5100, LC 7.5 Coils/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, AIRAID MIT, Perfect Power SMT-5, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 227K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 02-26-2023, 08:25 PM #6
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
My .02
I like 555 parts! Good advice!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 12:43 AM #7
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
FYI: Forum consensus, developed over many years and many reports from members, is to strongly prefer only OEM Toyota lower ball joints. 555 Sankei have been reported---anecdotally, of course--- as failing early.
Look at it this way: The Toyota OEM design is weak, engineering-wise. Why go down market from there?
pluton is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 01:36 AM #8
Noted. The pair I bought came in Sankei 555 branded packaging, made in Japan. I was under the impression that Sankei is an OEM manufacturer for Toyota. These units seem super-high quality to me. The casting of the arm in which the LBJs are mounted looked far better than anything I saw at the typical parts houses. Is it possible that the complaints of poor quality are from folks who got counterfeit goods?
Old 02-27-2023, 08:04 AM #9
Slowgoat's Avatar
Slowgoat's Avatar
Thanks for this input. You learn something every day!
Old 02-27-2023, 09:01 AM #10
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
The overwhelming consensus on this forum (and it's been that way for many years) is to only use OEM LBJ's and replace the bolts. I highly recommend you take that advise.
As to your original question, I believe most guys say every 100k miles. If you wheel a decent amount, you may want to replace sooner.
Good luck
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-27-2023, 09:55 AM #11
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is just really nice JoeT4R is just really nice JoeT4R is just really nice JoeT4R is just really nice JoeT4R is just really nice
JoeT4R's Avatar
I agree with the above and @pluton , with as something as crucial and important like LBJ's, I'd definitely go OEM and nothing but. Things like, timing belt, water pump, VCG's and a few others to name a few. You can't risk something like that with aftermarket parts.
2001 SR5 4WD | 325K+ | Build Thread
Old 02-27-2023, 09:57 AM #12
96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light
When needed YMMV.
You can do the by the book inspection if you have the tools, .5mm(.020") wear limit hard to see with naked eye.
For a rough check I do the prybar check when doing tire rotation, if you can see movement with naked eye
your in the Oh Chit stage. What brand you use up to you, I go Toyota.
Old 02-27-2023, 05:39 PM #13
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
555 stuff is generally very good, and they are an OEM supplier for Toyota - maybe even for the 3rd gen lower ball joints. The problem is, the aftermarket parts are not the same design as the OEM ball joints, which is the problem.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-27-2023, 05:56 PM #14
Copy that. I thought having a greaseable joint would be better. I made this decision before joining this forum. This forum did not come up in any of my searches at the time when researching LBJ's. I found out about the 2001-02 recall and felt like avoiding an OEM joint due to that issue...
But, thanks everyone for all the input.
Cheers.
Old 02-27-2023, 07:31 PM #15
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
The one time I dropped my guard I got burnt.
Have always gone with factory Toyota OEM replacement parts when replacing a critical part or a part that involves a lot of labor to replace.
LBJ replacement…….OEM from reputable online Toyota dealer parts dept.
Same thing when I replaced rear wheel bearings, retainers & seals as well as valve covers and related parts.
Couldn’t resist the lower price advertised on eBay for supposedly factory OEM parts when time came to replace the inner tie rods.
They arrived couple weeks after purchase but I didn’t attempt to install for almost a year later.
Once I removed the original OEM parts I quickly realized the replacement parts were counterfeit parts and not OEM as advertised.
Purchased another pair from reputable Toyota dealer, lesson learned.
Still have the counterfeit parts on my workbench to remind myself never to make the same mistake 2X!
When it comes to LBJ’s, go OEM directly from the dealer.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
ball , joints , lower , miles , replaced
WTB: 3rd gen lower ball joints OEM NEW nytosc Want to Buy/Trade 1 07-25-2020 05:52 PM
How to replace 3rd Gen lower ball joints. Pic Heavy. shawnstcyr 3rd gen T4Rs 41 05-29-2020 01:08 PM
Lower ball joints; can you replace the boot only? nytosc 4th Gen T4Rs 0 08-14-2017 01:55 AM
Lower Ball Joints bikerjosh 3rd gen T4Rs 22 07-15-2011 06:03 PM
Where to buy OEM Lower Ball Joints?! live4thrillz Maintenance/Detailing 3 06-13-2011 06:01 PM
