Old 02-28-2023, 05:55 PM #1
ChromeT4R ChromeT4R is offline
ChromeT4R is on a distinguished road
Regearing and rear axle seals
I'm looking at getting my 2wd 4cy 2000 4runner regeared. Since it currently has 220,000 miles should I get the rear axle seals replaced at the same time?
ChromeT4R is offline   Reply With QuoteReply With Quote
Old 02-28-2023, 06:34 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Yes. Might as well while the axle shafts are out. Just do a grease/sharpie test to make sure the new seal is in the right spot.
Old 02-28-2023, 07:24 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Buy 3 seals. If it's your first time, it's very easy to smash the seals up by accident. Freezing them beforehand helps a little with installation too as they shrink just a tiny bit and allow them to slide in easier.
326WHP 347TQ
Old 02-28-2023, 08:20 PM #4
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Agreed with the above. Also go OEM for the seals, don't do aftermarket ones. If they've lasted you this long then you can expect to double it from here forward.
Sent from my SM-S908U using Tapatalk
Old 02-28-2023, 08:54 PM #5
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Do wheel bearings while you are in there. You won't have to worry about that rear for a long time.
Old 03-01-2023, 12:59 AM #6
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
First of all, if you're gonna do a re-gear, I suggest using East Coast Gear Supply. You can order pre-built differentials and send yours back to satisfy the core charge.
You can pull the differentials yourself using these videos:
REAR DIFF SWAP
FRONT DIFF SWAP
WATCH FRONT DIFF SWAP PART 2 AS WELL FOR FURTHER HELPFUL INFO
In regards to the rear axle seals. You could just go for the seal replacements, but it would be better to do the whole job and replace the bearings, retainers and other associated parts too. The videos below will instruct you how to do it. Watch both videos and be sure to read the comments I pinned (1st comment you see) for further updates on the job
REAT AXLE SEAL JOB PART 1
REAR AXLE SEAL JOB PART 2
mtbtim is online now   Reply With QuoteReply With Quote
Old 03-01-2023, 08:40 PM #7
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
This, don't question this advice. I did and asked around trying to figure out why everyone screws up their first one. I thought I had it all figured out and only bought 2 seals. Sure enough I screwed up the first one too and had to eat some humble pie. They are only 7 bucks so there's basically no reason not to. Probably not a bad idea to just do the bearings while you are there too (definitely do this if you have noticed any gear oil that has made it past the seal, failure on bearings can be catastrophic and ruin your new gears). Also pretty cheap in the grand scheme of things if you can find someone with a press and the Donald press tool.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 10:53 AM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I always buy multiple seals. Having a bunch of 3rd gen buddies, it seems like someone is needing one. It's nice to just be like "oh yeah I got one on my part bin" and knock out a job instead of having to wait.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-03-2023, 08:29 AM #9
Wow great info! Thank you all for the information and advice. I didn't consider the bearings. Some more thinking to do.
Old 03-03-2023, 09:35 AM #10
If the back ends are the same as the 4wd you can get the actual OEM bearings much cheaper at Napa than you can the dealership btw. They are Koyo bearings.
'98 SR5 5 Speed
axle , rear , regearing , replaced , seals
Anyone in SD/OC that can help with rear axle seals? APhelps So Cal 4 03-20-2019 01:14 AM
Rear Axle Seals ksroqclimber 3rd gen T4Rs 22 10-13-2012 01:49 PM
Rear axle seals: how big a job? xStePheNyz 3rd gen T4Rs 5 01-09-2012 12:50 PM
96 rear axle seals brad7410 3rd gen T4Rs 3 11-07-2009 02:47 PM
Rear axle seals, once again. shawnstcyr 3rd gen T4Rs 1 07-10-2009 02:47 AM
