Old 03-05-2023, 02:16 AM #1
hiluxsurf1 hiluxsurf1 is offline
hiluxsurf1 is on a distinguished road
Rear fender flare removal
Hi guys,
I’ve found some rust up under my wheel wells around the rear quarter panels.
I’m wanting to fix this but was hoping to remove the rear fender flares so I could get a good look in there and see how bad it is.
Does anyone know how to get these off?
Seems there are rivets underneath the flare but there’s definitely something else somewhere.
Rear fender flare removal-8070ca0f-77c2-48e4-aab7-26864363cfd8-jpg
2000 Hilux Surf SSR-X Millennium Silver 3RZ
hiluxsurf1 is offline   Reply With QuoteReply With Quote
Old 03-05-2023, 12:07 PM #2
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
http://www.japan-parts.eu/US/3/750144H.png
Rivets and clips it looks like.
Old 03-05-2023, 12:54 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It's clips and maybe a bolt. I pulled limited flares off quite a while ago off one of my rigs.
Old 03-05-2023, 06:49 PM #4
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
See if this helps. Most are are just push pins, but there is a rivet at each of the two circled areas, which you can see by looking inside the wheelwell. Drill out the rivets, then start prying away.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 03-05-2023, 07:04 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I actually put limited flares on an sr5...lol
Old 03-05-2023, 08:40 PM #6
This is perfect thank you
bad , fender , flare , good , rear
Right Rear Upper Fender Flare Removal Question Rainier42 5th gen T4Rs 0 05-23-2022 03:43 PM
Holes after fender flare removal DontRoastMePlease 3rd gen T4Rs 4 07-29-2021 10:50 PM
Fender flare removal question 4RUNNERgeo 3rd gen T4Rs 10 01-19-2013 06:30 PM
'07 Loose Rear Fender Flare (removal ?) SCA 4th Gen T4Rs 2 11-30-2007 10:15 AM
