Old 03-08-2023, 09:53 AM #1
Toya! Toya! is offline
Toya! is on a distinguished road
Very weird braking issue
Hey everyone, I am having an odd issue with my 99 limited. I bought the truck with soft/squishy brakes. Took it home and replaced the original MC with a new OEM one, bled the brakes got my peddle back or so i thought.
When backing out of my garage, the peddle sank like it did before, but if I press it a hair faster it is a stiff normal peddle. I have gone through the entire system and there are no leaks but the lines are a little crusty. I have new ones ready to be put in but im wondering what else to try and fix this. I only drive it around the block right now because of the random soft peddle. I am pretty hesistant to blame the MC since it is a brand new OEM replacement (bench bled and all). I've also tried activating ABS to get all the air out. I might try that one more time too..
Idk if you any of you have experienced this before or have an idea for a fix please let me know!
Toya! is offline   Reply With QuoteReply With Quote
Old 03-08-2023, 09:57 AM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Are your rear brakes adjusted up properly? Is your brake booster and it's check valve working properly?
The goto the floor out of the blue can be the brake booster check valve sticking.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 03-08-2023, 10:32 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
Did you follow the FSM procedure for bleeding the master cylinder? It's different than normal bench bleeding.
Old 03-08-2023, 10:50 AM #4
Rears are adjusted correctly that I know for sure! I didnt know about the check valve. Assuming it is cheap I might just replace it. Brake booster works fine tho, or at least I think it is
Old 03-08-2023, 11:21 AM #5
Do you have a link? I can never find the FSM for 96-00. All my FSMs have the electronic MC procedures
Old 03-08-2023, 02:32 PM #6
Real Name: Patrick
Real Name: Patrick
This post shows the procedure. There's a valve in the master cylinder that will only bleed if you follow the FSM procedure. No clue on the valve's purpose or function.
https://www.toyota-4runner.org/3547783-post14.html
Old 03-08-2023, 03:39 PM #7
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Here's the picture directly:
The little extra tube on the side of the master cylinder helps with brake feel with the rear drums. It has to be 'set' correctly with the above procedure (and bleeding has to happen in the right order) to make it work - otherwise no pedal pressure...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-08-2023, 03:52 PM #8
nissanh nissanh is offline
Do you have any bearing play in front wheels?
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 03-08-2023, 04:29 PM #9
Thanks for the links and pictures! The MC was bled using this procedure. I dont have any play in the front wheel bearings as well. Looking through forum posts and 3rd gen mafia facebook posts, it seems like this is has happened to other people. Just no definitive solution that I can find.
If it helps, when the peddle does go to the floor, it seems like its only the front engage, but when its working correctly I feel all 4 brakes solidly slow.
Old 03-09-2023, 01:08 AM #10
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
If I had to guess it's your ABS pump. I had the same issue where i'd pretty much have to have the brake pedal on the floor before the brakes started working. Replaced a ton of stuff and did everything mentioned here and nothing fixed it. Went and got a junkyard ABS pump and put it in and brake pedal was fixed. Idk what was wrong with it but something was.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | Kings Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders
toverturf is offline   Reply With QuoteReply With Quote
Old 03-09-2023, 01:38 AM #11
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
Had a very similar issue with my 00' limited and it turned out it was the brake booster.
Sent from my SM-F936U using Tapatalk
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 03-09-2023, 09:52 AM #12
I have done this, I cant remember the forum title but it was one of the first things I found and tried. My ABS works fine, as I have taken it down some dirt roads to try and pump out any residual air. So I would like to check that as ok.
Any idea what could cause that? Or any way to check the brake booster before replacing? I always thought a failed booster results in a stiff pedal.
bled , brakes , fix , oem , peddle
weird braking issue Frontline 4th Gen T4Rs 8 03-10-2016 09:53 PM
Weird braking sensation on pedal Runner Up 4th Gen T4Rs 42 01-23-2015 03:51 AM
Weird 'popping' sound when braking matthewm 3rd gen T4Rs 4 08-01-2014 07:03 AM
Weird braking issue M1911 4th Gen T4Rs 18 07-26-2010 01:31 PM
Weird sound when braking rdakhan Problems & Warranty Issues 6 02-12-2006 10:27 PM
