Old 03-08-2023, 10:01 PM #1
Rushthezeppelin Rushthezeppelin is online now
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
4wd light engaging but no light when cold
This has been happening for a while and since it's just the light I haven't really given it a ton of thought but figured I should at least try to figure this out at some point. 98 with good ol J shifter. It hasn't been truly warm in a while and I've only needed it when cold and it's always been cold where I go wheeling so far. Pretty sure it was coming on fine for the first few weeks I had the truck in late fall and we were still seeing 70s. If I've been driving a while and engage it it comes on right away but if the truck is cold it won't engage till I've driven a bit. I assume it has something to do with the temp of the front diff which is leading me to the ADD position sensor. Think I should pull the sensor and try and clean it up and maybe throw some contact cleaner on it? Seems to me that's the only option. The transfer and ADD are definitely engaging as I'm getting binding on dry pavement. Anyone else ever had this issue? Kind of bugging me now that I've addressed many of the more pressing issues with the truck and I need to track down the smaller gremlins like this. Also have an issue with the ABS that seems to be vaguely related to temp that happened after I changed the second side on my axle seals (I think I might have damaged the wire going to that sensor).
'98 SR5 5 Speed
Rushthezeppelin is online now   Reply With QuoteReply With Quote
Old 03-08-2023, 10:17 PM #2
One other strange detail I almost forgot about. If I have it engaged with no light and go back into 2hi the light will come on very dim (so dim I can only see it at night) for a period of time.
'98 SR5 5 Speed
Old 03-08-2023, 10:42 PM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Very common bad switch issue. My one is hit and miss on the 4wd light. Most likely, you need to replace that switch to correct thar issue..
brillo_76 is online now   Reply With QuoteReply With Quote
Old 03-08-2023, 10:53 PM #4
Interesting that I didn't find that issue in a search, I suppose I'll try to pull it out and clean it and if that doesn't fix it I'll see about snagging one at a pick n pull when I go there for some lower control arms soon (figuring it will be less headaches if I grab a set of arms for $40 to swap my whiteline bushings into rather than pulling the arms on my truck and having it potentially on stands for a while if I run into issues).
'98 SR5 5 Speed
Old 03-08-2023, 10:59 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It's 50 /50 on the used switches. Cleaning may work.
Mine been iffy for at least 5 to 7 years now. As long as the 4wd engages. I am happy.. lol.
I have a limited 97 that doesn't like to come out of 4wd. Gotta love the actuator controlled ones.
Old 03-09-2023, 10:47 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future Bad Luck has a brilliant future
Real Name: Patrick
I would suspect the ADD switch or the wiring circuit for it. That switch/circuit is responsible for illuminating the 4wd dash light. Since the front ADD is engaging then the 4wd switch/circuit on the transfer case is functioning properly and powering the ADD control relay to switch vacuum to the ADD actuator.
You can try removing the switch and cleaning it with contact cleaner while depressing the switch multiple times to see if that fixes your issue.
Old 03-09-2023, 10:54 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Being it's works sometimes. I thinking it's the switch. As if it were the wiring it probably wouldn't work at all. Granted anything is possible. Toyota was smart to use 2 switches for that indicator circuit. Makes troubleshooting easier.
Old 03-09-2023, 11:07 AM #8
That's what I'm thinking, diff warms up, switch warms up and things expand just enough to where a short becomes a contact, maybe because of a dirty contact in the switch. Wouldn't make sense with the wiring as I can' see that getting warm enough to be subject to thermal expansion. Maybe if it's really close to the switch or even in the connector to the switch, I'll make sure to spray that too.
'98 SR5 5 Speed
add , cold , light , sensor , truck
When engaging 4L should the yellow 4LO light blink and chime? nyvram 5th gen T4Rs 5 01-06-2022 09:58 PM
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
4x4 Not Engaging - No dash light Misfit Runner 3rd gen T4Rs 15 12-19-2017 05:05 PM
Center differential light flashing and not engaging please help mr.nugen 4th Gen T4Rs 20 08-28-2014 04:21 PM
ABS light comes on when its cold outside. ComBckKid_95T4R Classic T4Rs 0 05-04-2013 11:51 AM
