Old 03-28-2023, 03:36 PM #76
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
Originally Posted by Spiker Engineering View Post
The last piece to be painted, the main electrical harness holddown, was fun because I had to paint it without taking it out of the engine compartment. So I wrapped plastic all around the engine bay, leaving just the harness holddown exposed - I felt like a surgeon doing open heart surgery
Seems like you went the hard route? You can pull the harness into the bay and remove the metal piece, I believe... This is what i did when wiring in my 4WD wires:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-28-2023, 07:10 PM #77
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold Spiker Engineering is a splendid one to behold
official vendor
Ha, I was wondering about that! I looked under the dash, even pulled out the glove box, but could not get anywhere near the connectors. I decided it must require some significant disassembly for the HVAC ducting to get the to the connectors. No?
The open heart surgery approach wasn't all that hard, just tedious.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 08:01 PM #78
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
At least you didn't do what my po of a 1991 camry did. They decided to cut the harness and then connect all the wires back together, crossing a few. That was fun to trace and fix....:/
Old 03-29-2023, 01:09 PM #79
Pulling the harness into the bay itself is harder on the gen2 Camry (I've done it a bunch...) but getting the dash apart is just a touch easier. I've seen people completely unplug the engine harness rather than pull it out from the interior, which is also a bit crazy. The main fuse box has plugs for all the wires on the bottom, so removing the engine with harness attached isn't too bad.
On the 4Runner, you just have to remove the upper panel at the top of the glove compartment to access all the connectors. It is a bit of a pain to find remove some of the clips, but it isn't too crazy. Then just 3 of the 4/5 connectors at the ECU and two to the dash to pull it into the bay
The previous owner of my 4WD parts truck cut the harness there at the firewall too, which was annoying...
Old 03-29-2023, 02:58 PM #80
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I actually did that. My first engine camry. I completely unplugged the engine harness off the engine and dropped it over the passenger fender.
Old 04-08-2023, 02:06 PM #81
official vendor
official vendor
I finally received all the parts I ordered to finish the project. Looks like enough parts to open a Toyota dealership:
I also picked up the plated fasteners from the plating shop:
Some parts came out great:
Others I'm less than happy with:
I'm not a plater, but comparing what I received (left) to some new zinc plated nuts (right), I'm not happy. So I'll be taking them back to the plating shop to see what they can do.
Old 04-08-2023, 02:15 PM #82
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I don't blame you. Quality is important..
Old 04-09-2023, 11:43 PM #83
chapolito's Avatar
chapolito chapolito is offline
chapolito will become famous soon enough chapolito will become famous soon enough
chapolito's Avatar
How are you keeping track of what goes where? Did you just take a million photos along the way?
chapolito is offline   Reply With QuoteReply With Quote
Old 04-10-2023, 12:29 AM #84
official vendor
official vendor
Pretty much - I tried to take a photo of every fastener as I removed it, like this:
Old 04-10-2023, 09:04 AM #85
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is a jewel in the rough Romeo1 is a jewel in the rough Romeo1 is a jewel in the rough Romeo1 is a jewel in the rough
Romeo1's Avatar
Lots of ways to keep track of where hardware goes. Photos and video are awesome. A little work up front in the process saves major time on the back end.
Trays or muffin sheets with labels are great too. Tape with writing, locate tabs, anything really all works well to help you remember where things good.
Good systems and good organization is key.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 04-10-2023, 09:43 AM #86
official vendor
official vendor
Agreed. Since I took all the fasteners in for plating, I couldn't take any of the usual organization steps like trays, labels, or tape. So I will be relying on the photos I took during teardown to put it all back together.
Old 04-11-2023, 08:25 PM #87
official vendor
official vendor
I dropped off the fasteners back at the plating shop, they said they'll try to make them look better, but also said that I may need to go to a different shop.
In the meantime, I cleaned up the alternator a little bit, and threw in a new brush set, PN 27370-35060.
Old 04-13-2023, 05:56 PM #88
official vendor
official vendor
I got the re-plated parts back from the shop. Second time was the charm, apparently, the parts came out great.
I asked them what they did differently the second time, they were a bit cagey, just said that they "worked at it a little more". I suspect the reality is that the first time I got the "give 'im the usual" job, but when I came back complaining, they put the "oh this guy is picky, we better get this right" guy on the job.
Anyway, I think I can start putting things back together!
Old 04-29-2023, 09:41 AM #89
official vendor
official vendor
Well after much delays and chasing an issue with the IAC, it's (mostly) done! Still have a few parts on order, but this is the gist of it:
Old 04-29-2023, 05:25 PM #90
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice
Ed_C's Avatar
Real Name: Ed
Daaamn
bay , corroded , engine , replace , valve
Engine loud metallic engine rattle @1800 rpm after sitting in traffic protist 3rd gen T4Rs 5 08-17-2019 08:04 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
Engine Pull Project soundmanlpte 3rd gen T4Rs 5 03-21-2016 05:27 PM
New project done!! 02 4Runner engine swap ready to sale 4Runnermex 3rd gen T4Rs 12 01-23-2016 08:52 PM
