Old 03-10-2023, 01:55 PM #1
Atomic_Dog Atomic_Dog is offline
Atomic_Dog is on a distinguished road
Unexpected spark plug issue
My newly acquired 2001 with 130k miles was running perfectly, so I decided to mess with it anyway. I replaced the NGK iridium single ground plugs with NGK Platinum dual ground plugs. Now I have a stumble at idle below 1000rpm. I confirmed the gap with a wire gap gauge. I replaced the wires with NGK a few weeks ago and it was fine. I thought maybe too much dielectric grease, so I cleaned everything with no change. Wires are routed correctly. Suggestions?
2001 SR5 130k miles
Atomic_Dog is offline   Reply With QuoteReply With Quote
Old 03-10-2023, 02:47 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Coils are not making or possibility starting to fail. You can find the testing procedure in my signature for the v6.
Old 03-10-2023, 04:11 PM #3
Thanks. I re-installed the old plugs and it runs fine again. I'll try new coils with the new plugs.
2001 SR5 130k miles
Old 03-10-2023, 05:11 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
wait a min... Where did you buy these ngk iridium's from? If eBay or amazon I am guessing you got some counterfeits. :-(
Old 03-10-2023, 05:30 PM #5
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Dielectric means NON conducting. It's an insulator to keep the fire from going where it shouldn't. You should put it inside the boot but not on the connector or the metal tip of the plug. You can put it on the ceramic portion of the plug to help removal.
I made that mistake a long time ago on some NGK plugs and got the same result as you; misfiring plugs. I cleaned the plugs and connectors with something (maybe alcohol) and reconnected. It fired up and ran fine. Clean all of the metal on the plug and wire connector where you put the grease.
It's fine if you want to use it for something like coating your battery terminals, but not putting it on the terminals before you make the connection. Even so, it would still jump that very small gap. On a high energy ignition like a spark plug it will block it.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 03-10-2023, 05:38 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
On the actual connections. its best to use conductive grease. I personally, put nothing on my spark plugs connections and have no issues. :-)
"Dielectric means NON conducting" yes it best to be on the outside of a circuit not in the connector itself. Sort of put on after the circuit is together to keep the water out.. :-)
Old 03-10-2023, 06:00 PM #7
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Did you replace your wires too? Were any damaged prior to installation?
Sent from my SM-S908U using Tapatalk
Old 03-10-2023, 06:41 PM #8
spartacus's Avatar
spartacus's Avatar
The coil boots also wear out eventually. If there is discoloration on the boot end then time to replace just the boots.
Old 03-10-2023, 07:07 PM #9
The plugs came from Rock Auto. The only variable here is the plugs. New plugs misfire and old plugs don't. One of the new plugs did not discolor like the rest in the short time it ran. I'm guessing that one wasn't always firing. I'm thinking I may have gotten some copper anti-seize or something on the tip. Of course it was the last one I changed back, so I'll have to re-install the new ones again. As for the grease, I would've thought high voltage would be more likely to jump the gap, not less. Like when you get zapped by static before you touch the door knob. Or when a plug wire has a bad spot and the voltage jumps to a nearby ground.
2001 SR5 130k miles
Old 03-11-2023, 12:23 AM #10
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Spark plug voltage is very high, amperage is low (but high enough to give you a good zap). Static electricity, like when you shuffle across a floor or just walk across a room is also high voltage, low amperage. Bottom line is not to put anything on your spark plug connections. They should be clean and dry. Anything you put on those contact points is going to reduce the voltage sent to the plug and you don't want that. The boot will keep the contacts clean.
Rich
Kentucky
Old 03-11-2023, 05:17 AM #11
I’m also thinking you got knockoff NGK plugs.
You can call NGK and they can tell you if they are real plugs or fake ones based on the numbers they ask for from the plugs.
Old 03-11-2023, 11:25 AM #12
Well... I cleaned off the excess dielectric grease and the anti-seize that had gotten on the tip of one plug. Re-installed the new plugs and no problems. Basically I got complacent doing something I've done a thousand times before. Thanks for all the help and tips. I learned something new about dielectric grease in the process.
2001 SR5 130k miles
Old 03-11-2023, 01:00 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Excellent news. Glad it's fixed
ground , ngk , plugs , replaced , wires
Spark Plug Too Long? Hitting Socket? Issue Cylinder 6 rocky.mtn Maintenance/Detailing 5 10-27-2022 07:04 PM
Spark Plug Too Long? Hitting Socket? Issue Cylinder 6 rocky.mtn 3rd gen T4Rs 3 10-18-2022 07:26 PM
spark plug rounded, remove spark plug tubes? Danger Mouse 3rd gen T4Rs 0 05-02-2021 03:43 PM
Spark plug issue Merk RR Maintenance/Detailing 1 09-22-2016 04:31 PM
Spark Plug Wire Issue-Need Help JMat 3rd gen T4Rs 3 02-27-2013 01:46 AM
