Old 03-30-2023, 08:20 PM #31
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Okay after a little bit more looking there's actually almost no curvature on the bezel. Talked to my roommate, he has a 3d printer that can print up to 8x8 and thinks it should be something very doable for him to do. He hasn't actually really gotten the thing fully setup and really printed anything with it so he's actually kind of stoked to try this out so he has a good excuse to get it up and running. If we figure something out with the 3d printer then of course I will share the files on this. Also once I get a proper sized hole cut in the bezel I can make a paper template to scan so that people can easily replicate that part since that would probably be the trickiest part of getting a clean finish. This also allows me to make the piece coming out from the back of the bezel and sticking out with a little flang that you can bond to the bezel which should help a lot with stability.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 03-30-2023, 10:52 PM #32
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Okie dokie smookie... I observe this project. I get it..you go.
Old 03-31-2023, 01:14 AM #33
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Just for navigation, it would probably be way cheaper, at least in terms of labor,
to put a mount on the A-pillar for a Garmin or TomTom unit for that in-your-
face location.
The radio bezel is not screwed down, and it's really carrying no weight. Any
head unit mounted to it is likely to rattle the bezel loose from the push tab
slots in the center stack (especially if driven off road), assuming it doesn't
break from the weight first.
It might be possible to build a metal HU mount that screws to the actual
radio or heat/ac control location. This could include a new mount for the
control, too. It could also be built in pieces or a smaller piece, rather than
one huge piece.
The heat/ac vent hoses could be a separate bezel, below the radio and heat/ac
control, for instance. Or the hoses could vent in the middle with the control
at the bottom in the original radio location. Then, yeah, some fiberglass
fabrication might be necessary, but the whole deal would be a lot stronger
than trying to rely on the bezel alone.
My problem (at least one of them) is I like the vents up high at the stock
location. I'm not sure putting them in the middle would work as well.
I don't have a picture for it yet, so I'll keep head-tripping it; I'd like a 10"
unit high enough to really see.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 08:42 AM #34
face location.
one huge piece.
Actually that's not true. There are two screws around the climate controls that hold the bezel quite securely and that is directly below the mounting location I'm looking at. This is easily the most sturdy part of the bezel especially on 96-98s because of the cupholder is well, that thing is stiff. At least one of the examples linked clearly offroaded a lot with his truck and I presume had no issues with a setup like this. Part of my plan as far as structural is possibly to have a structural member (piece of metal likely) coming down off the din mount to rest right on top of the climate controls (I'll probably put a piece of foam there so it doesn't rattle like crazy). Just not a fan of separate pieces of equipment for things like navigation. Having things be seamless as far as function appeals to me. If the absolute worst happen though I'm not really out much as I will still have my original bezel while I'm putting this things through it's paces and can swap back. I plan on probably just blocking the upper vent off with some foam and/or tape instead of hacking it apart so this whole thing should be fairly easily reversible (I would just cover the hole in the lower plenum to close that off). If this is successful though hopefully I will have figured out a way for others to ditch the annoying stock radio location without a ton of effort and still remain decently stock looking. As far as vent location I don't think I would mind that at all. One advantage I see to it is it will warm my shift knob on cold days. Perhaps I'm wrong though, we will find out lol.
'98 SR5 5 Speed
Old 04-08-2023, 06:12 PM #35
Well decided to mess around in tinkercad (never used it before but I have a lot of experience with 3d modeling software so didn't take too long to figure it out). Have what I think is a halfway decent rough draft for the part I want to print based off measurements and actually holding the part up to my screen to try and figure out the angle lol (appears to be damn close to 35*).
This is essentially a front facing view of the part. Those lips will catch the back side of the bezel and that bottom piece should rest almost perfectly on top of the cup holder on one side. Sides and top are 1/4" and bottom is 3/8". Then I would just epoxy it into place and maybe add some pieces of metal for more rigidity if I think it's needed which I suspect it won't, we will see. Also I know basically nothing about 3d printing so I'm not even sure if this is a shape that will print easily lol.
'98 SR5 5 Speed
Old 04-08-2023, 07:25 PM #36
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I've dabbled in 3d printing before, it looks simple enough to print, whatever printer you use would just need to add supports to hold up the top part
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 04-08-2023, 08:14 PM #37
19963.4lsr5 19963.4lsr5 is online now
I’ve sware I’ve seen moving the radio up to where the heater controls are but not all the way to the top.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 04-09-2023, 08:58 AM #38
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Nice! Do you still plan to use the Atoto HU?
Old 04-09-2023, 06:46 PM #39
Looks like it's the only HU that fits the criteria I'm looking for and is not a mystery company with non-existent CS or would cost me an arm and a leg for the same functionality so ye I'm still going with the Atoto. It's sitting in my save for later in my amazon cart. Also have an outside temp display, vents and a flush mount USB port sitting in there. I think this might end up with a really clean look without having learn how to do fiberglass. Might use some interior trim paint too to keep everything color matching. Also thinking about putting a midland GMRS in the ashtray slot. The ideas on this are snowballing too. I'm figuring while I have all the interior trim apart to do the backup cam to I'm going to prewire and plumb for onboard air and might do some sound proofing.
'98 SR5 5 Speed
Old 06-09-2023, 12:07 PM #40
snowkiid snowkiid is offline
snowkiid is on a distinguished road
Red face Any updates?
I’m in castle rock so not too far from littleton. This is a mod I have been following since you started the post. Just curious if you managed to succeed with it? And if so mind posting the final results?
snowkiid is offline   Reply With QuoteReply With Quote
Old 06-11-2023, 06:34 PM #41
Naw kinda stalled out waiting for my roommate to get his 3d printer up and running which he is kind of taking his time with it. Thinking about asking around my 4x4 club to see if anyone can get the ball rolling on this quicker. I've had the atoto head unit installed in the factory slot for a bit now and one thing I'm realizing is that I'll probably have to make the system a little beefier than I originally anticipated if it will hold up to washboards. I'm thinking I could run a steel plate off the cupholder to support it and lock it in place. I think this is about the only way to get this to work. Thought about maybe having the mount actually tied into the dash like the factory din slot but that was dashed when I took things apart the other day to blue locktite the factory slot (screws rattled loose a bit on a fishing trip I was on that involved lots of driving on washboards). it would require A LOT of fab and possibly some welding which is beyond my capability. I'll just overbuild it as much as I can and maybe even find ways to reinforce the radio bezel and stiffen it.
'98 SR5 5 Speed
Old 06-16-2023, 11:58 AM #42
Well if you ever do find a good way to do this mod. let me know! i will drive down to littleton and give you some cash to do mine haha. in the meantime ill be trying to figure out a way to as well. If your 4x4 club gets the ball rolling on it always be sure to post updates back to here.
thanks
Old 06-28-2023, 02:41 PM #43
Green_Bean Green_Bean is offline
Green_Bean is on a distinguished road
couldn't you try poking around some 3d printing forums to see if anyone can help you get this piece printed and shipped to you. maybe even the guy that makes the cup holders. Also is the design uploaded anywhere I would like to try it out.
Green_Bean is offline   Reply With QuoteReply With Quote
Old 06-29-2023, 09:55 AM #44
There is a guy in my club actually who is going to print it up for me. Rather busy with a bunch of stuff right now though so it might be a bit till I get this all wrapped up. I want to make a few modifications to the file but I'd be happy to post my beta version up here for you in a bit.
'98 SR5 5 Speed
Old 06-29-2023, 11:33 AM #45
poisedforflight poisedforflight is offline
poisedforflight is on a distinguished road
I can't wait to see your finished product. This is a mod that has my interest.
poisedforflight is offline   Reply With QuoteReply With Quote
air , bezel , head , unit , vents
Installing aftermarket head unit- utilize JBL or use head unit amp nytosc 4th Gen T4Rs 3 07-10-2017 08:43 PM
swapping factory head units in the 3rd gen bak3rme 3rd gen T4Rs 4 11-02-2011 03:41 PM
Convert JBL Head unit to Scion Unit ttman Engines / Suspension / Wheels / Tires / Audio / Accessories 9 08-19-2008 05:48 PM
new head unit and speakers, or just new head unit? 4Running4Life Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-06-2006 02:24 PM
Head gasket swapping? yotatilla Classic T4Rs 0 09-17-2005 10:32 PM
