Old 03-12-2023, 07:05 PM #1
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
light bar wire question
first ...up here light bars are called moose lights
2nd....last time i installed a moose light on 3rd gen I went direct to battery...which ment always had power
3rd...i did do a search but could not find an answer.
so im gonna install a moose light on my current 4runner (light has a relay and switch). I want it to switch off when ignition is off. I dont care if it lights on high beams..ive got a rocker and sometimes dont need the extra light on our poor headlights and dont want to use my fog light switch...as I use my fogs.
I plan to use one of those fuse taps...but not sure what fuse can handle the extra load. If I should tie into the one inside by our knees or the one under the hood...and what size fuse tap.
wont have time to play and guess. I have a garage available for 2 days ( and will be sleeping there...house sitting)...but im gonna be doing vc gaskets, fuel filter, heater control valve, rear hatch struts, a alternator, drive belts and a ps flush.. I wont have a rig to chase after parts while im down so trying to line up everything I can think of.
ohh... according to box...light pulls 15 amp max its 120 watt led using 15 gauge wire
ideas ?
so any ideas would be helpful so I can order stuff if needed
Old 03-12-2023, 09:13 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The relay would be handling all the amperage of the light bar so the switch won’t need much. I would recommend tapping into a fuse in the cab that only has power with the key on running that to the switch then running the other side of the switch out to the relay. By tapping into a fuse that only has key on power the light bar won’t be able to stay on when the key is off so no chance of draining the battery accidentally.
Old 03-13-2023, 09:32 AM #3
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
^ this. If it the relay harness doesn't already have one, put a fuse at the battery + wire to the relay.
Old 03-13-2023, 12:02 PM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by Ed_C View Post
... If it the relay harness doesn't already have one, put a fuse at the battery + wire to the relay.
Best advice Possible. Right at the battery for max protection....
Old 03-13-2023, 02:48 PM #5
Wire the 'power' side of the relay directly to the battery. Wire the coil side of the relay (power to the switch -> relay) to any ignition power source inside the truck. You CAN but don't NEED to put a fuse on that, since it will already be fused by the truck wiring.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-13-2023, 07:05 PM #6
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Not an answer to your question, but I am getting ready to add 2 or maybe 4 little rock lights to the side rails on my roof rack (mainly so I can see how many of 'em I'm up against when I sleep in my truck out on the BLM lands). This or something like it will be handling the external wire run
I'm going to run an inside switch to hit the lights without the key in.
Old 09-24-2023, 10:34 PM #7
Real Name: 3 Bears
Real Name: 3 Bears
been meaning to thank you and all who replied, I did tag into the cigarette lighter wire....dont need that one..and now i have a moose light that shuts off when key off.....however...could not find a switch that said moose...wanted something different...so switch says "zombie light"
it is such a thin gauge wire but I figured if its on a 10 amp circuit with other acessories, and can handle the load of a lighter then it should be able to handle the load of a relay
Old 09-25-2023, 09:23 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Zombie light.. I like it...
extra , fuse , light , moose , switch
Reverse light wire momo.75 4th Gen T4Rs 15 01-09-2022 11:10 PM
Help me wire my light bar switch woodman60 4th Gen T4Rs 3 05-22-2018 12:20 AM
ABS/VSC light after spacer- ABS wire Cracka Problems & Warranty Issues 9 05-20-2018 07:29 PM
Brake Light Wire Color - Please Help 97silverlude 3rd gen T4Rs 2 06-13-2007 08:55 AM
