Originally Posted by phattyduck
A shorting plug exists that plugs in there that was uses on manual hub Tacomas... though no idea if you can actually GET it.
I would suggest using the small sub-harness that goes between that plug and the ADD switch as the spot to do the short - that way, you or a future owner can easily re-enable the ADD switch for some reason.
I agree with your idea. Another possible option is to contact a place like Aeromotive or Connector Experts and get that other side of that plug. They will likely be able to sell you a plug with some wires for 75 bucks that you can use, and avoid any hacking of the factory wiring.
