Old 03-13-2023, 02:25 PM #1
RidingDirty RidingDirty is offline
RidingDirty is on a distinguished road
How to ADD wire delete?
Hey I recently did the manual hub and non-ADD tube conversion on my front axle. Afterwards I was left with a single 2-wire plug that used to go into the ADD tube (as shown in photos) which is located on the left side. It is my understanding that since this wire is unplugged, the 4WD light on the dash will no longer work. So if I want the 4WD dash light to function properly, than I would need to cut the plastic plug off and connect the 2 wires (twist/crimp/solder). Is that the correct process? There used to be a website that detailed it pretty well (4x4wire.com), but the website doesn't look like it exists anymore. So can anyone help me out? Thanks.
ADD Defeated...No more failures!
http://www.4x4wire.com/toyota/tech/add
How to ADD wire delete?-dscn5388-jpg  How to ADD wire delete?-dscn5391-jpg
RidingDirty is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 03:08 PM #2
phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future phattyduck has a brilliant future
A shorting plug exists that plugs in there that was uses on manual hub Tacomas... though no idea if you can actually GET it.
I would suggest using the small sub-harness that goes between that plug and the ADD switch as the spot to do the short - that way, you or a future owner can easily re-enable the ADD switch for some reason.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-14-2023, 09:52 AM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I agree with your idea. Another possible option is to contact a place like Aeromotive or Connector Experts and get that other side of that plug. They will likely be able to sell you a plug with some wires for 75 bucks that you can use, and avoid any hacking of the factory wiring.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-15-2023, 08:44 PM #4
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
You are correct on connecting the 2 wires together. I did mine many years ago and remembered there being a short pigtail I cut off and soldered them together leaving the plug on the main harness intact.
You could always just pull the pins out of the connector and tape them together if you don't want to cut the wires.
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
4wd , dash , left , light , website
Adapting a 3-wire gear driven VSS to a 2-wire electronic VSS harness? derekwilliams345 3rd gen T4Rs 10 01-11-2021 02:11 PM
Rear Wiper - To delete or not delete? SpidermanGeek 3rd gen T4Rs 3 01-29-2015 09:53 PM
Cigarette lighter wire tap - wire location? Nashvegas34 3rd gen T4Rs 7 03-03-2012 10:52 PM
How to wire speakers? Directly from amp or back to HU through stock speaker wire Woody17 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 04-18-2009 07:36 PM
