Old 03-13-2023, 07:08 PM #1
mymalade mymalade is offline
mymalade is on a distinguished road
Burnt valve prevention?
Is it possible to prevent a burnt valve issue? It might be a bit too late for my 2.7, but I've been reading about them burning valves and requiring a new head/rebuild and apparently it's very common. There is an excellent video from Timmy the tool Man on YouTube on adjusting the valves, is that the proper way to prevent a burn up? Or is there something else I should try and do, assuming I don't already have a burned valve since I have a rough idle issue that I can't find.
2000 3rz with 190k for reference.
mymalade is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 07:23 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Valve adjustment is the only proven prevention for burnt valves
EDIT: they do make some top end engine cleaners that you can use to try and clean the back side of the valves. I’m not a believer of it but some people are. Beware that it is known to kill catalytic converters if they aren’t in good condition.
Old 03-13-2023, 07:27 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup. Check valve clearance. I 100% agree.
Old 03-13-2023, 07:39 PM #4
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
The more I think about it, I probably really should check the valve clearance on my donor 2.7 while its sitting on the stand before dropping it into my pickup. Sucks I slept on the good valve tool on amazon and the are no longer available though
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 08:02 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Not a bad idea. I know its a pile easier to to valve cover gaskets etc with the engine on an engine stand.
When I redid a v6 i was going to throw in my 1997 limited resealed the engine and changed the timing belt etc along with both main seals. We even redid the oil pan gasket. :-)
Old 03-13-2023, 08:56 PM #6
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Quiet valves are tight valves, and tight valves are burnt valves. Keep them adjust and keep them ticking.
JohnMc is offline   Reply With QuoteReply With Quote
Old 03-13-2023, 09:26 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Don't supercharge it. Heat can make the valves fail prematurely.
326WHP 347TQ
burnt , issue , prevent , valve , valves
How long does it take to develope symptoms of burnt valve? Pyral 3rd gen T4Rs 28 12-23-2021 12:02 AM
Is my CEL burnt out? atalarico 3rd gen T4Rs 3 04-13-2016 04:17 PM
22RE Burnt Valve??? Give me your thoughts jlewis74 Classic T4Rs 16 03-31-2012 08:37 AM
Burnt Valve. What to do. jlewis74 Classic T4Rs 15 03-23-2012 10:35 AM
EG007-02 03/22/2002 Valve Cover Oil Baffle - Damage Prevention CBR_GUY_IA TSB 0 07-12-2009 11:17 PM
