Old 03-15-2023, 08:51 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral will become famous soon enough Pyral will become famous soon enough
Pyral's Avatar
Real Name: N/A
Where to get a power steering hose that is as overbuilt as the original
I replaced the power steering return line today. Despite me getting a replacement that is suitable, the original hose was twice as thick as the new one, I had to use smaller clips. It feels like a downgrade even if the original hose is 25 years old. I don't think I'll find such an overbuilt part in any Autozone.
The original hose is made by Yokohama, can I still get them through Toyota? It's not a part that is unique enough for Toyota to give a part number
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 03-15-2023, 09:36 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future brillo_76 has a brilliant future
brillo_76's Avatar
Real Name: Jon
Looking like aftermarket only. Unless, you find a good OEM used one somewhere. :-(
Old 03-16-2023, 06:46 AM #3
96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light 96RedRunner is a glorious beacon of light
Look around your area for place that makes Hydraulic Hose's.
You'll need OD measurement of nipple on Rez and steel tube at rack, OD of orginal hose.
Best selection to choose from.
Old 03-16-2023, 07:20 AM #4
Any transmission cooler line will do the job.
It’s nothing special and it is not under any pressure.
Old 03-16-2023, 08:51 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes I always forgot about the hydraulic hose makers. That's definitely an option.
The pressure line does have a metal non crushing sleeve in it that a found out exists at a pick and pull when pulling a power steering pump out of a wrecked one.
Old 03-16-2023, 08:56 AM #6
For me it was finding the correct fit rubber ID to hardline OD.
Old 03-16-2023, 09:11 AM #7
Current price for OE pressure line is $370.00 + shipping tax off the shelf, a shop can beat that.
It's a handy option to know of a place if you get in a bind or refurbing.
Edit: Find the local place that makes heavy equipment hoses hit up local equipment operators.
A good/pro industial shop will spec new hose/fittings to OE specs.
Old 03-16-2023, 11:00 AM #8
You entire return line needed replaced……
Old 03-16-2023, 03:42 PM #9
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I went to the dealership today, the guy at the counter said the same thing. If you want the hose you have to buy the whole replacement return line including the metal hoses, which is over $300.
Obviously that isn’t going to happen. The stuff that you can buy by the foot from Toyota isn’t going to be any different from what you can get from a parts store.
Yokahama doesn’t sell their hoses to normal consumers, seems like they only sell in bulk. So if you want something as robust as the original part, your only option is to go with hydraulic hoses.
Old 03-16-2023, 04:26 PM #10
No, All I've replaced are the two pieces of hose on L/P side. Took going to Industrial place for the ID"-OD" OE dimensions and type of hose. OE clamps worked no problem.
"Current price for OE pressure line is $370.00"
Same Industrial place said they could build a H/P line for half dealer cost. Pre-covid price sure it's higher now.
Old 03-16-2023, 05:00 PM #11
In a nut shell. Doesn't have to be hydraulic hose just the appropriately constructed higher end rubber hose correct dimensions.
Better grade of hose than I've found in chain parts houses.
Find a one stop shop for an ace up your sleave if/when you need a HP hose.
Old 03-16-2023, 07:39 PM #12
You wanted another (larger OD) hose to be able to use the spring clamps?
Old 03-17-2023, 01:09 PM #13
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Just for posterity, the banjo fitting on the pump side of the high pressure hose has a sensor in it. Not sure if a hydraulic hose shop would be able to maybe a hose that had that specific sensor built into the banjo fitting.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
hose , original , overbuilt , part , steering
Power steering hose size bob3dsf 4th Gen T4Rs 2 06-05-2022 06:40 PM
Hopefully this will help other members--POWER STEERING HOSE wingzerom31996 4th Gen T4Rs 0 11-02-2019 08:37 PM
Power steering hose Daneums 3rd gen T4Rs 3 04-15-2017 11:12 PM
Power steering hose diameter Erich_121 4th Gen T4Rs 0 10-06-2013 06:53 PM
Wanted:Power steering pump/AC hose for a 92-V6 Jeff Rodriguez Classifieds - buy & sell (no commercial ads please) 0 08-03-2005 07:36 AM
