Old 03-17-2023, 03:16 PM #1
95Z28A4 95Z28A4 is offline
95Z28A4 is on a distinguished road
Hayden 698 transmission cooler install with custom brackets.
I just read a thread on this site where a member was requesting someone manufacture custom brackets to mount a transmission cooler directly to the radiator support.
3rd Gen 4runner External Tranny Cooler Install w/ Radiator and Thermostat Replacement
I decided to share photos of the brackets I made to install a Hayden 698 in my son-in-law's 1997 SR5 4Runer. The brackets are made from 1"x1/8" flat bar and 1/8" plate. The bracket near the headlight is one piece. The bracket near the center is made of two pieces and welded together. I used two bowls to form the inside and outside radii of the curved piece. The bowls are 6-1/4" and 8-1/2" respectively. The top of the bracket near the headlight is attached to original passenger side horn mount with the original bolt. The rest of the fasteners are 1/4" bolts. The bottom of the center bracket is attached to the radiator support with a 1/4" rivet nut. Providing you can weld, these brackets are not difficult to make.
Like many others, I relocated the passenger side horn to the driver side. Instead of extending the wire, I pulled it from the loom.
While I was at, I replaced all of the transmission hoses, because the originals were becoming mushy.
Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_1-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_2-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_3-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_6-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_7-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_8-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_10-jpg
95Z28A4 is offline   Reply With QuoteReply With Quote
Old 03-17-2023, 03:20 PM #2
More photos
Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_11-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_12-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_13-jpg  Hayden 698 transmission cooler install with custom brackets.-1997-4runner-hayden-oil-cooler_14-jpg
Old 03-18-2023, 01:48 PM #3
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
looks really clean
hntz4x4 is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 02:12 PM #4
Originally Posted by hntz4x4 View Post
looks really clean
Thanks!
Old 03-21-2023, 02:33 PM #5
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
They make a ‘zip tie’ that holds it on as well. Goes in between the fins of the cooler and radiator.
Ran that for years before I found a 5-speed to swap in.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 12:12 PM #6
nissanh nissanh is offline
Looks good! Also, note that you are missing the bottom part of the fan shroud. this part is still available to purchase new or get one from a yard. this will also significantly help the fan to pull air THROUGH the radiator than from the open area.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 03-23-2023, 02:29 PM #7
The cooler came with a set of 4 zip ties. I used that method for mounting a transmission cooler in a Jeep Cherokee about 20 years ago. I didn't like it. I've fabricated brackets for every transmission cooler I have installed since then.
Old 03-23-2023, 02:33 PM #8
Thanks!
I did not realize there the shroud has a bottom piece. Are you talking about part #16702? Do I need part #16702A to install it?
Hayden 698 transmission cooler install with custom brackets.-1997-4runner-fan-shroud_1-jpg
Old 03-23-2023, 02:37 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by 95Z28A4 View Post
Thanks!
16702 is the lower shroud. You'll need 2 of 16702A to attach it if I remember correctly.
bracket , brackets , made , side , transmission
Hayden 678 Transmission Cooler TonyB66 3rd gen T4Rs 17 08-23-2021 02:03 PM
Hayden 699 Transmission Cooler KF4R2011 5th gen T4Rs 9 05-07-2020 09:19 AM
Hayden transmission cooler vs. B&M FiXXXerX 3rd gen T4Rs 13 07-10-2018 11:29 AM
Hayden 402 Transmission Cooler Write-Up 02_SE_Runner 3rd gen T4Rs 5 08-25-2014 01:33 PM
TRD Transmission cooler vs Hayden Smobien 4th Gen T4Rs 1 06-06-2013 04:50 PM
