TheDurk
and
HiLife
are correct. You deviate from the Denso Alts or Starters with an autoparts refmg junk rebuild.
You will definitely be changing them again and again. I learned this 25 to 30 years ago.
Only exception is if you rebuild those components yourself with new toyota parts and contacts.
Aftermarket brushes and contacts are not the same quality as the oem denso.
I guess they will learn. I won't use anything but Denso in Toyotas. I seen what happens if you dont...:[
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
