Old 03-18-2023, 02:58 PM #1
maxthebird maxthebird is offline
maxthebird is on a distinguished road
Intermittent no click no start on 1998 4runner V6
My 4runner just developed an intermittent no click no start issue. When I turn the key to accessary everything lights up but continuing to the starting position, there is no click and no starter activation. Turing the ignition key off then on again starts the truck fine. Sometimes it takes 2 or 3 tries but it does start right up once the starter get going. My first thought was that the battery connections were loose but everything is tight with no visible corrosion. I also suspect that the starter may be bad but not hearing the solenoid click leads me to believe that it's ok and that juice isn't getting to the starter. I'll check the starter relay in the fusebox next but since the problem is intermittent, I suspect (and hope) that maybe there is a contact problem in the key switch. Brillo_76 addressed this in an old post where he replaced the ignition start contact in the key switch, after having replaced the starter and not solving the problem. I'd like to try replacing the ignition start contacts before replacing the starter. Brillo_76 or anyone else that has done this who could provide some directions would sure be appreciated. Thanks.
maxthebird is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 04:21 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Supposedly, it's rare that rear ignition connection goes. I just know it fooled me and replaced a starter that wasn't bad. So, if everything else is checking out. Verify that the start connection is good.
Old 03-18-2023, 06:05 PM #3
Any words of wisdom on how to check the start connection? Do I remove the ignition key lock and are the connections behind it. How do I check for a good connection and are there contacts available from Toyota for replacement? Have never had the ignition lock out before. Thanks.
Old 03-18-2023, 06:12 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Sounds like textbook starter contacts needing replacement. I’d personally start there before messing with the ignition.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 06:17 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I actually had a spare ignition connector. You could buy them. The electrical wiring diagram for your year will show you what colors the wires are.
I would just verify continuity on those 2 wires in the connector.
I just took the ignition connection out and tested it with a meter...
Old 03-18-2023, 06:21 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I do always say if everything else is checking out good..
Old 03-21-2023, 06:26 AM #7
dork0900 dork0900 is offline
dork0900 is on a distinguished road
If your battery and starter are good, check your neutral safety switch. My 98 4runner is starting every time now that I replaced that switch.
dork0900 is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 08:09 PM #8
Starter replaced and all seems good. Only been a couple of days. Time will tell since it was an intermittent problem. Thanks for all the replies.
Old 03-31-2023, 09:46 PM #9
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I hope you didn't sacrifice a factory Denso with worn contacts for an aftermarket reman that will crap out in months. The Denso might last the life of the truck with a new set of contacts.
My Backyard Frame Swap
Old 03-31-2023, 10:05 PM #10
HiLife HiLife is offline
The masses are unaware the stellar reliability of a denso and submit as core.
Old 03-31-2023, 10:29 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@TheDurk and @HiLife are correct. You deviate from the Denso Alts or Starters with an autoparts refmg junk rebuild.
You will definitely be changing them again and again. I learned this 25 to 30 years ago.
Only exception is if you rebuild those components yourself with new toyota parts and contacts.
Aftermarket brushes and contacts are not the same quality as the oem denso.
I guess they will learn. I won't use anything but Denso in Toyotas. I seen what happens if you dont...:[
Old 03-31-2023, 11:22 PM #12
Thumbs up
Unless the buyer are so lucky enough to get a reboxed Denso reman in a box from the autoparts store.
They are out there, although lesser and lesser chance of getting one.
Old 03-31-2023, 11:44 PM #13
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
This. It is so important to use Denso or OEM parts on our trucks. It's not a difficult concept to grasp. These trucks love Denso products.
Accurate.
Truth. Preach it. Save those Denso products and rebuild or have them rebuilt! Eating that core charge is nothing compared to having to shell out the funds for a new starter, alternator, etc. But if you have the originals rebuilt then that won't ever have to become a reality.
Sent from my SM-S908U using Tapatalk
click , key , problem , start , starter
4runner does not start. Only click noise by fuse box, no check engine light Garcia9876 3rd gen T4Rs 2 08-18-2022 03:21 PM
99 won't start, no click Gospinn 3rd gen T4Rs 37 07-20-2021 11:16 AM
1998 4runner Intermittent AC MK_98 3rd gen T4Rs 12 06-22-2017 10:31 PM
98 4Runner One Click- wait then will start 98RaleighRunner 3rd gen T4Rs 6 03-01-2017 12:57 AM
2002 4Runner - Intermittent Problem - Cranks but won't Start bluependa 3rd gen T4Rs 3 07-28-2013 06:18 PM
