Old 03-18-2023, 04:17 PM #1
Johnnie Johnnie is offline
Johnnie is on a distinguished road
brakes dragging on my 99 Help
In the process of trouble shooting a battery drain(turned out to be the anti lock brake power wire) I unhooked the power line and the drain went away. the problem now is the brakes intermittently work normal (normal pedal) or stiff hard pedal with no play before activating brakes resulting in the brake pads dragging on the disc , of course brakes get hot. now it doesn't matter if the power is hooked up for the antiknock brakes or not. its got 300K on the vehicle, I don't want to spend a fortune at a shop but I was hoping to use it for a few more years. has anyone heard of this problem before
Johnnie is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 04:39 PM #2
1776FreeRunr 1776FreeRunr is offline
1776FreeRunr is on a distinguished road
Have you checked it with ODB scanner for codes? If you are planning on keeping it for several more years, I would just start replacing everything related to the system starting with the ABS brake module/pump motor and see if the problem persists. I wouldn't drive it until you have this issue resolved for safety reasons. https://www.youtube.com/watch?v=95VqQB2ixHU Hope this helps you out.
1776FreeRunr is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 05:01 PM #3
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I agree with psalm, if your problem was the power wire to the ABS module I'd bet something went bad in there and was shorting out the wire
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 03-18-2023, 08:02 PM #4
the problem with the shot gun approach is all that stuff with the antilock brake system would add up to way more than the vehicle is worth, those are very expensive components. I was hoping someone else had been thru this. there was no check engine lite but I'll check for OBD codes anyway, and also no ABS light except when I remove power from the system
Old 03-18-2023, 08:17 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Almost have to be the abs module or the actuator.
Unplug each one separately and see if the current draw goes away.
Does the ABS still work?
Old 03-19-2023, 11:14 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
ABS/Airbag (SRS) cannot be checked with an OBD scanner. The codes must be flashed through the engine bay diagnostic port.
Old 03-20-2023, 07:24 AM #7
This would be a good topic to Ask Scotty Kilmer's advice. He is trouble shooting expert and has tons of experience with Toyotas.
Old 03-20-2023, 01:44 PM #8
Real Name: Patrick
Real Name: Patrick
I really hope that was satire. The only thing Scotty Kilmer is good at is yelling obnoxiously at a camera, making biased claims with no evidence or based on 80's vehicles, and coming up with click bait.
Old 03-21-2023, 02:40 PM #9
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
You forgot about his real talent which is convincing people with no car knowledge that he is highly knowledgeable.
Skulking is offline   Reply With QuoteReply With Quote
Old 03-21-2023, 03:16 PM #10
Real Name: Patrick
Real Name: Patrick
How could I forget?! LOL thanks for the correction! He's the worst thing to happen to the automotive community since the Imported Vehicle Safety Compliance Act of 1988.
Old 04-14-2023, 08:56 PM #11
figured it out
I had 2 separate problems at the same time the ABS module was bad at least as far as drawing down the battery when the vehicle was parked, new abs module was over 1000 from dealer, I took a chance for 50 and bought used on ebay and battery draw went away. dragging brakes was still there(front) I changed the master cylinder and now the brakes work, must have a valve in there that wasnt letting all the brake fluid go back to the master cylinder when the brakes heated up, now everything works normal, I never saw a master cylinder act like that before. also had to replace brake pads they were as thin as paper. (back in the saddle again) the runner has now reached 299k miles on original motor and trans. should join the 300k club soon
Old 04-14-2023, 09:22 PM #12
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
Glad you figured it out on the cheap.
...and for the record. I think Scotty Kilmer is hilarious.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
brake , brakes , normal , pedal , power
Brakes seem to be dragging after new parts. Lockcuff 5th gen T4Rs 16 01-29-2021 02:53 PM
Front Brakes dragging tristero 5th gen T4Rs 10 06-16-2018 11:28 PM
Brakes Dragging? FlyNavy 5th gen T4Rs 7 04-14-2011 03:02 PM
Brakes dragging on all 4 wheels jimkmi 4th Gen T4Rs 1 04-09-2011 09:47 PM
95 brakes dragging slipknoter106 Classic T4Rs 1 03-20-2011 11:12 AM
