Old 03-23-2023, 07:47 AM #1
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Cold start turnover idle dip
For the last week when I start my rig first thing in the morning it turns over fine but the RPMS immediately dip when it turns over like it's going to stall for a split second before it idles up. Otherwise it's running fine. I cleaned the throttle body a couple months ago so it should be fairly clean in there. It's also running a high idle for longer than I'd expect given that it's about 70 degrees in the mornings. It's almost like it's running like it's winter temps. Maybe IAC problem? Thoughts?
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 03-23-2023, 08:15 AM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Mine does the exact same thing. On cold morning starts (I'm in Wisconsin though), after it fires up, it idles low for a split second than comes up to normal idle rpm.
I've never worried about it.....
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 03-23-2023, 02:15 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like IAC or dirty MAF to me. Of those two I would think dirty IAC.
Old 03-23-2023, 02:27 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
This is a great place to start. Clean the MAF first as it's only a few clamps and the thing comes out. The IAC takes a bit longer to do.
326WHP 347TQ
Old 03-23-2023, 05:46 PM #5
I cleaned the MAF a couple months ago when I cleaned the throttle body but I could give it another squirt.
Old 03-24-2023, 11:17 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Rough idea is mostly the MAF sensor or the IAC. Or a vacuum leak. I agree with the others. On focusing on those 2 parts.
Old 03-25-2023, 01:27 AM #7
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
I’ve had this issue. Mines actually died. It hasn’t happened again. I never actually did anything and it went away lol. I should try what these guys suggested.
MarkBlack is offline   Reply With QuoteReply With Quote
Old 03-25-2023, 02:21 PM #8
Real Name: Jerod
Real Name: Jerod
If it's the IAC just wait until a very hot day outside. It'll die again.
326WHP 347TQ
Old 03-25-2023, 04:01 PM #9
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
My educated guess is your IAC valve is a little sticky. I think you should test it and clean it.
dip , fine , idle , running , turns
Cold start idle orcking 5th gen T4Rs 9 11-10-2022 12:17 PM
High idle on cold start 808islerunner 3rd gen T4Rs 7 03-05-2016 09:58 AM
06 4.0 v6 will not start or turnover any suggestions? Teqeeler 4th Gen T4Rs 11 08-26-2015 05:44 PM
Rough idle at cold start runnyrunnerton 3rd gen T4Rs 16 08-28-2014 07:49 AM
Low idle on cold start - '88 22re bishopsRobes Classic T4Rs 1 12-06-2010 11:19 PM
