Originally Posted by blarchitect
Thanks for the reply. There is only one local welder here and it costs a dollar for a gulp of air in his shop. The hitch was $50 and it would cost way more than that to fab some brackets. Was wondering if anyone had come up with a novel/MacGyver alternative?
If I remember correctly, you might be able to stick a breaker bar into the open frame rail with the bumper removed. If this is the case, then you could bypass the whole weld plate altogether. It will probably be a hassle to get the bolts threaded into the "loose" nuts, but if you don't plan to take it off again (or don't mind the future hassle when you do), then this is also an option.
Come to think of it, I had to use a hole on the side of the frame rail to access the nut closest to the front of the truck when the nuts broke loose from the weld plate.
